[SOLVED] Advancing time and with sporked shreds.
Page 1 of 1 [6 Posts]
agkbill
PostPosted: Sun Dec 19, 2010 1:29 pm    Post subject: [SOLVED] Advancing time and with sporked shreds. Reply with quote  Mark this post and the followings unread
I have a code that look like this:
Code:
fun void flash()
    while( true )
      1 => f_led;
      for( 0 => int i; i < 3; i++ )
     for( 0 => int j; j < 3; j++ )
       if( p_led_flash[i][j] == 1 )
         xmit.startMsg("/sleep/led", "iii");
         i => xmit.addInt;
         j => xmit.addInt;
         f_led => xmit.addInt;
   1000::ms => now;
   0 => f_led;
         i => xmit.addInt;
         j => xmit.addInt;
   1000::ms => now;
      <<<"x-flash" , x>>>;
      <<<"y-flash" , y>>>;
      <<<"f_led-flash" , f_led>>>;
spork~ flash();
[ [0, 0, 0], [0, 2, 0], [0, 0, 0] ] @=> int p_led_s[][];
while( true )
  //zero matrix
      0 => p_led_flash[i][j];
      0 => p_led_on[i][j];
      0 => p_led_off[i][j];
      if( p_led_s[i][j] == 2 )
   // add into flash led matrix
   1 => p_led_flash[i][j];
      if( p_led_s[i][j] ==  1)
   // add into normal led matrix
   1 => p_led_on[i][j];
      if( p_led_s[i][j] == 0 )
   1 => p_led_off[i][j];
c
<<<" ------------------------------------------------- NEXT ---------------">>>;
But what causing me problem is the time deley I put in, for example
Code:
2000::ms => now;
and
Code:
1000::ms => now;
It is when I have it in both places, main code and the sporked part. If I delete from one of the places the code run but with it in both places everything halts.
I guess I missed something in how => now; is working.
I need the time delay in the sporked part because I making a led to flash in that way.
I also need it in main part to control progress there.
Any ide on how to deal with this?
All input most appreciated.
Best regards,
/Christer
vrachnasormora
PostPosted: Sun Dec 19, 2010 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Christer,
your code works fine for me.I can't find anything weird into it.I tried to reconstruct your code with the missing variables and added the "2000::ms => now" part at the end of the main loop ( I guess you replaced it with the "c" character in the code you posted ) and it just runs.This is it:
Code:
int f_led;
[ [ 0, 0, 0 ], [ 0, 0, 0 ], [ 0, 0, 0 ] ] @=> int p_led_flash[][];
[ [ 0, 0, 0 ], [ 0, 0, 0 ], [ 0, 0, 0 ] ] @=> int p_led_on[][];
[ [ 0, 0, 0 ], [ 0, 0, 0 ], [ 0, 0, 0 ] ] @=> int p_led_off[][];
OscSend xmit;
xmit.setHost( "localhost", 6449 );
fun void flash()
    while( true )
        1 => f_led;
                    i => xmit.addInt;
                    j => xmit.addInt;
        1000::ms => now;
        0 => f_led;
                    i => xmit.addInt;
                    j => xmit.addInt;
        1000::ms => now;
        //<<<"x-flash" , x>>>;
        //<<<"y-flash" , y>>>;
        //<<<"f_led-flash" , f_led>>>;
spork~ flash();
while( true )
    //zero matrix
    2000::ms => now;
Maybe you should search elsewhere for the source of your problem.
Hope it helps
Andreas
agkbill
PostPosted: Mon Dec 20, 2010 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you vrachnasormora,
Ok, the problem is not that I have several
Code:
2000::ms => now;
instructions in both main code and spork~ processes.
I am glad to sort that out. Now I just have to keep on looking for what cause the unwanted behavior.
All the best!
/Christer
Audio files: 211
G2 patch files: 92
PostPosted: Mon Dec 20, 2010 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if you tested with a monome, vrachnasormora, but anyway I tried your version, and I got the second row second column led flashing on my monome.
I had to change the port to 8080 to match my old default setting in monomeserial, and ChucK doesn't give any error even though you transmit to a port where no one is listening. Have you double-checked that the ports match, Christer?
/Stefan
vrachnasormora
PostPosted: Mon Dec 20, 2010 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
No, Stefan, I don't have a monome.I just completed the code Christer sent with the variables and their values missing in order to check how it runs.The choice of the port number was random.
Andreas
agkbill
PostPosted: Mon Dec 20, 2010 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments,
I have managed to find the problem. It was not in the chucK code but rather in the way monome handle OSC I would believe.
I noticed that when I added the code:
Code:
fun void on()
    while( write_out == 1 )
     if( p_led_on[i][j] == 1 )
         i => xmit.addInt;
         j => xmit.addInt;
         1 => xmit.addInt;
         <<<"¤¤on¤¤">>>;
spork~ on();
That is the function to layout the layer of no flash led on the monome, it all freeze up.
It seems to be when to much data is sent to the monome, it get to much and it stop to respond.
Code:
fun void on()
         i => xmit.addInt;
         j => xmit.addInt;
         1 => xmit.addInt;
         <<<"¤¤on¤¤">>>;
      step_time => now;
spork~ on();
So I put the time for each step in the main loop and put it in a "dur" that I called step_time and then used that one to delay the loop until next step. In that way I only send data each step and not all the time.
it looks like it working.
Thank you for all input!
All the best!
/Christer
Niio1
