  bingsatellites Mostly Ambient
Drum replacement with a stethoscope as trigger in Protools?
KV
PostPosted: Sat Mar 02, 2013 10:46 pm    Post subject: Drum replacement with a stethoscope as trigger in Protools?
Subject description: Help needed for replacing sounds from a stethoscope with recorded samples
Hi all,
I'm trying to help out a friend with her art installation. It's in a confined space that uses several hidden speakers and the majority of the sound is supposed to come from a stethoscope, which has an audio output. The area she's got to work in is so tight, that the stethoscope is feeding back in the speakers (despite my efforts to EQ the feedback away, use a noise gate to minimise unwanted noises etc).
So I wondered if there's a drum replacement plug-in that's designed to be used for live use - where we can load in some pre-recorded heartbeat samples, and the signal from the stethoscope can just trigger back the sounds in realtime with the participant's heartbeat rhythm.
My friend uses ProTools and unfortunately I'm a total noob with that program... so I'm hoping some bright spark here on the forums knows a bit more about this sort of thing than I do. Tips or advice would be very useful!
Best,
-Anthony
mps board
