jean-louise
Posted: Thu Oct 27, 2011 8:34 am Post subject:
basic question(s) about cmos clocks |
hello!
though i did some diy stuff before like making a little quad NAND / vactrol noise machine and a baby-8 sequencer, i haven't really got a background in electronics.
so from time to time (quite often actually ) i come across something basic i can't figure out myself. despite searching this exremely helpful forum and googling i don't know how to solve this question:
i got a baby-8 running on 9 volts and want to feed its 40106 clock to another circuit based on the "fun with seamoss"-sequencer (4040, 4051) running on 3 Volts.
is it necessary to step down the clock voltage to 3 Volts?
and if so how do i do that - does it suffice to hook up a simple voltage divider with say 10k and 20k resistors?
(i'd like to keep that second circuit at 3 to max 4,5 Volts in order to avoid using an 7805 regulator for a third circuit getting it's power from the same battery.)
thanks for your help!!
greetings
jan |
fluxmonkey
Posted: Thu Oct 27, 2011 6:51 pm Post subject:
all of the circuits on the fun w/ sea moss page are designed to run on 9v... i run lots of 4000 cmos stuff on 15 volts no problem, tho you might have to tweek the R/C values a bit. go for it! _________________ www.fluxmonkey.com |
Joined: Dec 11, 2010 Posts: 482 Location: Toronto, Ontario - Canada
Audio files: 29
Posted: Thu Oct 27, 2011 7:52 pm Post subject:
CMOS clock signals shouldn't exceed the supply voltage.
It will need to be stepped down the same voltage that the chip receiving the clock is running at.
I'm a noob, so I have no idea how to safely do that without using a 78xx |
jean-louise
Posted: Thu Oct 27, 2011 8:10 pm Post subject:
hey fluxmonkey,
thanks for your answer!
--but it's not really what i meant!
the problem is this:
i'd really like to use this circuit with 3 Volts (so another circuit can share the same battery without the need for a voltage regulator) but want to have the possibility to feed it a 9 Volt clock pulse.
and i am afraid i'll damage the ICs with that voltage.
how to process the clock if necessary?
just a voltage divider?
it's kind of a stupid question, but i didn't come across this situation before, because in the past i just used 9 Volts for everything.
jan |
jean-louise
Posted: Thu Oct 27, 2011 8:21 pm Post subject:
| Cynosure wrote: |
yes, that's exactly my problem - is there a possibility if don't want to use a voltage regulator?
how do you do it with lunettastyle instruments if you meet and want to hook up your machines for some inter-modulation and one runs on 9 V and the other on 5 Volts?
I believe it's not a big problem to attenuate CV-Signals(?) Is it the same with Cmos-Signals or is there a difference because of current or impendance?
jan |
jean-louise
Posted: Thu Oct 27, 2011 8:25 pm Post subject:
| Cynosure wrote: | CMOS clock signals shouldn't exceed the supply voltage.
and thanks for confirming this. i wasn't even sure about that.  |
Joined: Apr 03, 2004 Posts: 19572 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Oct 28, 2011 11:15 am Post subject:
You could use a 2.7 V zener diode to ground over the 3 V input, then feed the 9 V signal into that through a resistor, of say like 10 k. _________________ Jan |
jean-louise
Posted: Sun Oct 30, 2011 8:52 am Post subject:
Hey Jan,
Is this solution preferable to the voltage divider - and why?
greetings
Jan |
Audio files: 116
G2 patch files: 317
Posted: Sun Oct 30, 2011 9:01 am Post subject:
Yeah, it would always clip around 2.7 V whereas a resistive thing would depend on the ingoing voltage. Of course when that ingoing voltage is fixed always a resistor would do the job as well, and a bit cheaper. _________________ Jan |
jean-louise
Posted: Sun Oct 30, 2011 9:15 am Post subject:
Aaah, now I get it!
Thanks again!
j |
