USB-MIDI question
Page 1 of 1 [4 Posts]
patrickvf1976
PostPosted: Sun Mar 18, 2012 7:21 pm    Post subject: USB-MIDI question Reply with quote  Mark this post and the followings unread
I was wondering if it was possible to use a usb hub as a midi bay for usb-midi adapters/cables? If it's possible then I could get rid if my midi thru boxes which take up real estate in the power strip.
PostPosted: Mon Mar 19, 2012 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
It's possible if you do all the MIDI routing inside the computer. But you will get latency with any I/O to the PC (3-4ms), while a MIDI-Thru has maybe a nanosecond or two latency at worst. That's about 2,000 times worse. Wink
You'd be better just getting a MIDI patchbay/interface like the MOTU MIDI Express XT that can be a computer interface and do routing from one port to another at the same time.
patrickvf1976
PostPosted: Mon Mar 19, 2012 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
But that depends on the memory/cpu type and speed of the pc, right? Or does the latency issue come from the hub itself? I can't really afford anything right now, so I was hoping that a cheap usb port would do good enough, but I guess it won't unless I use some low latency software/OS. Well thanks for your insight, I'll probably just get another power strip.
Another question (I don't remember if I posted this question before) - I have an opcode 6x midi thru box and another 2x thru box, the opcode has two midi/mac com inputs, one per 3x trhu - can I - theoretically - use the outs from the 2x thru box to hook it up to the opcode one and have 6 outputs available for gear or are there some limitations that I need to consider?
I would additionally like some gear to inter-communicate with oher gear (e.g. Korg EG1 with MoPhatt, ESQ1 with Fatman, etc) or should I just use one software sequencer for everything? Can you suggest a possible solution?
laura woodswalker
Audio files: 10
PostPosted: Mon Mar 26, 2012 2:51 pm    Post subject: Re: USB-MIDI question Reply with quote  Mark this post and the followings unread
I have been using one! I have a Novation SLMKii MIDI controller to a USB hub and then I just tried attaching my Korg Microsampler via a USB cable.
I also have my Xstation synth as part of the rig, although that is connected to the Other usb input.
I didn't have any latency issues, but then I am also using a Tascam 144 audio interface.
I am using a regular desktop computer, but I am told that a laptop may not be able to power all of those USB connections unless I buy a Powered USB hub.
COmplicated isnt it!! Rolling Eyes
The most important music equipment is what's in front of the instrument.
