tbone
Posted: Sat Jul 02, 2011 1:29 pm Post subject:
Rhythmic Subject description: 4017 and 40106 |
This is my first post but I have been lurking and absorbing here for a little while.
This is a quick demo of my first real Lunetta type unit made out of a 4017 and 2 40106s. I've made APCs and 40106 oscillator synths but not combined with anything else.
I found a 4017 in a compartment of my toolbox [I'm not sure why, I don't even remember ordering it] and so built a sequencer based on the baby 10. I then tried hooking up the sequencer outputs to the oscillators of a 40106 and liked the sounds I was getting out of it so decided to mount it all up to some banana jacks [forward planning so I can later combine it with some more modules].
Anyway, here is a video:
Thanks! |
Draal
Joined: May 18, 2010 Posts: 284 Location: Oak Park, IL
Posted: Sat Jul 02, 2011 6:14 pm Post subject:
Welcome aboard tbone . Nice sounds and great looking unit. Hope to see and hear more of your stuff. _________________ Zontar Prevails! |
sndbyte
Posted: Sat Jul 02, 2011 10:18 pm Post subject:
| Very nice looking build. What did you use for the panel? |
tbone
Posted: Sun Jul 03, 2011 2:55 am Post subject:
The panel is a sheet of clear perspex which I have painted black on the underside. Using a clear sheet let me mark out all the points to drill holes etc on graph paper which I then stuck underneath to get everything neatly aligned. Painting on the underside gives a nice glossy look, but when putting it altogether I did chip a little paint off around one of the LEDs which does show on the front. If I were to do this again I would probably try and find something to apply over the paint to prevent that from happening. |
tony void
Posted: Sun Jul 03, 2011 7:40 am Post subject:
| Beautiful Machine Nice craftsmanship! |
tjookum
Joined: May 25, 2010 Posts: 350 Location: Netherlands
Audio files: 26
Posted: Mon Jul 04, 2011 4:12 am Post subject:
very nice work tbone, I really like the shine and the size is just about perfect for a lunetta.
What are you planning to add to this machine? I've build a few 4017 sequencers myself and I always added a 4066 cmos switch to mine so you can gate things like APC's, circuitbend toys, etc.
XOR, XNOR and NAND gates are also a lot of fun and very easy to do.
Looking forward to seeing your progress. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
tbone
Posted: Mon Jul 04, 2011 12:12 pm Post subject:
Thank you for the kind words!
A way to use it with some of my circuit bent gear is exactly what I was hoping to add next to this. Something along the lines of the sequencer on the casper electronics site [http://www.casperelectronics.com/images/finishedpieces/sequencers/switchScheme.jpg] looks to be ideal.
Tjookum, I do have a 4066. It is supposed to be for my echo base delay pedal build, but I need to get a few other things for that anyway so I may well use it before hand.... |
