X-4046 VCO Help
Page 1 of 1 [8 Posts]
tehskull
PostPosted: Thu Jul 14, 2011 11:07 am    Post subject: X-4046 VCO Help
Subject description: VCO Calibrating
Finished mine last night. Working on calibrating it now. I have only been doing DIY synths for about 3 months. This is my 4th completed module. Calibrating is going OK so far. When the VCO gets into higher octaves, it cuts off. Powering it off then on brings it back once the frequency is turned back down. Not sure if this is a characteristic of my 4046 or not (which is a motorola). The HF trimpot is set to maximum resistance per Thomas's calibration instructions. I am going to continue calibrating with tools now. However if anyone has any input it would be gratetfully appreciated. So far I am very happy with it. A very big thanks to Matthias and Thomas for this great project.
Andrew
Calibrating the VCO with MFOS 1v\oct calibrator.
 Filesize:  2.6 MB
 Viewed:  83 Time(s)
Completed module
 Filesize:  2.94 MB
 Viewed:  87 Time(s)
PostPosted: Thu Jul 14, 2011 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
apart from the oscillation stopping: as long as it oscillates, do you get it tuned to 1V/oct? and how many octaves do you get out of it?
fonitronik at
tehskull
PostPosted: Thu Jul 14, 2011 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am getting 8 octives just fine(my 1v\oct calibrator only goes to 8 ). It cuts off when I turn the Frequency pot up. I am trying a software oscilloscope tonight to do some more checking as i do not have a hardware oscilloscope.
PostPosted: Fri Jul 15, 2011 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
8 octaves? that's great.
by saying 'cut off' you say it is literally stopping to oscillate, and it does not start oscillating again when turning the coarse pot down again, until you switch off/on the module?
fonitronik at
diablojoy
PostPosted: Fri Jul 15, 2011 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
looking at the schematic if you can get 8 octaves with a CV into the 1v/oct input it does not leave much to check as the freq pot is summed to the same opamp
check +/- 15 volts either side of freq pot R43 -100k and that R29 is 100k
if all that checks OK then you do have something very strange going on.
PostPosted: Sat Jul 16, 2011 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
problem solved. he swapped the motorola for an NXP!
so the motorola does not seem to be a good choice all the time!?
fonitronik at
bubzy
Audio files: 47
PostPosted: Sat Jul 16, 2011 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
im wondering if the motorolas i have are the problem too. just cant find NXP's anywhere. any clues?
Level5
PostPosted: Sat Jul 16, 2011 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mouser P/N: 771-HEF4046BPN
Niio1
