Problems with my Stripboard-Sequencer (Baby-10)
Page 1 of 1 [3 Posts]
Juno60
PostPosted: Tue Sep 21, 2010 3:07 am    Post subject: Problems with my Stripboard-Sequencer (Baby-10) Reply with quote  Mark this post and the followings unread
Hello @ all,
for my DIY modular I made a stripboard layout of a simple 8-step sequencer. It's basicly a baby-10 sequencer. I added manual step, -reset as done by Fonik and a simple 555-clock.
But I guess there's something wrong, 'cause ist does not work. Can anyone please check my layout?
The internal Clock goes by a int./ext. switch on the panel to Ken Stones Gate2Trigger converter. The converters signal feeds the 4017 clock input.
When powering the sequencer several LEDs are lightend (not only the active step) and neither the internal, nor an external clock signal seem to affect the sequencer.
I built a baby-10 sequencer a year ago without any add-ons and it worked fine. So I guess there must be a mistake in the clock-input circuit. Maybe you can figure out what is wrong with that layout.
Thx a lot!
Chris
 Filesize:  157.69 KB
 Viewed:  349 Time(s)
Greetings from Germany,
Chris
Clack
PostPosted: Wed Nov 17, 2010 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
When somthing goes wrong with a stripboard, check the power supply voltage
You might be getting inteference on the switch .... i.e mains hum and its going at 60hz
check / re-solder the switch connections.
does manual step work?
last resort try replacing the 4017
Clacktronics.co.uk
citric acid
PostPosted: Thu Sep 29, 2011 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
hi chris,
haste den fehler schon gefunden. versuche mal den 555 weg zu lassen und mit einer extrenen clock zu triggern..geht das ?
habe den auch schon aufgebaut nur nicht mit dem step und reset.
hatte echt problemem mit dem 555 , als ich ihn weg gelassen habe tat er .
LG
http://soundcloud.com/citric-acid-303
Niio1
