MATLESTAR
Posted: Thu Nov 24, 2011 4:26 pm Post subject:
A6 FREEZING,SOME KNOBS NOT RESPONDING-HELP! Subject description: Andy has become generally glitchy to the point of unplayable now |
Hi There,
Ive had my A6 about 6 months now but recently it has started freezing. Buttons like :program,up/down menu,global,program group would all work but none of the knobs would have an affect.
For a while a simple turn on off would do but last week it happened as soon as i turned it on and remained that way. I did a soft reset (soft 4 on start up) and did the initialize global parameters and BINGO all was good. Not only that but everything workrd 10 times better and i realised Filter2 had never been working properly ( maybe the Andy had been upset in transit). The FREQ knob never really did that filter sweep that i was expecting but after the reset it did and i was over the moon!!
Sadly it didnt last long , maybe 4 days so i did another one which has now lasted 40 mins!
Has this happened to anyone before?? PLEASE HELP!! CHEERS |
Mefistophelees
Joined: Mar 06, 2011 Posts: 72 Location: l'Angleterre
Posted: Thu Nov 24, 2011 6:38 pm Post subject:
Re: A6 FREEZING,SOME KNOBS NOT RESPONDING-HELP! Subject description: Andy has become generally glitchy to the point of unplayable now |
| MATLESTAR wrote: | Hi There,
Turn a knob up to it's highest then down to it's lowest a couple of times.
Do this for all of them.
That might fix it.
I had something similar happen when I first got mine and doing that solved it. _________________ http://soundcloud.com/Mefistophelees |
sunny pedaal
Joined: Nov 16, 2004 Posts: 651 Location: netherlands
Audio files: 12
Posted: Sun Nov 27, 2011 5:39 am Post subject:
there should be a test mode for all buttons and knobs, something with start+ softbutton ? ( i don't have the manual right in front of me now )
otherwise a loose cable or cpu might cause it or something else afcourse
but indeed try buttons and knobs first , preferably in test mode.
if one sticks, strange things might happen |
MATLESTAR
Posted: Sun Dec 04, 2011 7:05 am Post subject:
wow it worked!!!! turned the knobs and it worked but only lasted about half hour but tried it again and ive now been happily re aqquainted with my a6 since your post
Thanks for the help, much appreciated!!!
have another query, please check my new post please! |
sunny pedaal
Audio files: 12
Posted: Sun Dec 04, 2011 8:24 am Post subject:
just two more tips:
always , always use a dust-cover when not using the a6, so many knobs and pots simply need it.
2. once in a while use a vacuumcleaner to suck up the dirt from your a6. put an nylonsock/pantysock around the tubes-end of the vacuumcleaner, to prevent sucking up some unwanted parts of your a6 too.
it's worth it. happy knobbing, glad to hear it works again ! |
