RG123
Posted: Sat May 14, 2011 5:45 pm Post subject:
Switch between mono/poly within patch? |
Hey there!
I've been lurking here for a while, but this is my first post (i think!). I'm the proud owner of a G2 keyboard as of last summer. Loving it, but i'm stuck on a few simple things...
I like to be able to switch between mono and poly modes on the fly (as is possible on my NL3). Unfortunately switching between these modes in the patch settings on the G2 cuts the sound off. Is there a way to do this without the sound cutting off? I've searched and can't seem to find it in any of the patches on here. It was discussed here...
http://electro-music.com/forum/topic-7341-0.html&postdays=0&postorder=asc&highlight=switching+mono+poly
but i didn't quite understand how to implement it (i'm a programming newbie, more of a player)
Amazing forum btw
I'd appreciate any help if anyone has a moment.
Thanks
Rob |
Joined: Apr 03, 2004 Posts: 19572 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat May 14, 2011 6:36 pm Post subject:
Welcome Rob.
The basic idea that thread starts with is to use both a keyboard and a monokey module.
You will not be able to use the shortcuts on modules then, like the keyboard tracking on oscillators or the automatic gate on envelope modules, and you need to route those manually from the keyboard modules.
The routing from the keyboard modules needs to switchable too - there are switch modules for that, the switch 2-1 module would be suitable and you'd want to switch the three signals that the keyboard modules have in common - pitch gate and velocity (the latter one comes in a linear and an exponential form on the keyboard module, I think exp would map to the velocity on the mono module).
Then the three switches need to be controlled by something, like another switch maybe which could be the switch on/off toggling.
However after going through all that trouble ... the patch would still not be completely monophonic, it would just make all voices play the same note in mono mode.
There are tricks to for that too - which would be a handful of other modules ... I'll explain that route if thats where you'd want to go.
The reason for the silence BTW is that the G2 is dynamic in how patch parts are distributed over it's calculation engines, that distribution needs to be recalculated when you alter voice counts for a patch and then a changed patch compilation gets loaded onto the DSPs, during that load time they need be silent as there state would be undefined then. _________________ Jan |
RG123
Posted: Sun May 15, 2011 4:52 pm Post subject:
Thanks for getting back to me!
I see what you mean about it not being proper mono. I think i'm gonna go with the 2 patch method (load one poly/one mono of the same patch and switch between), until my programming skills get better.
It certainly makes me appreciate all those switches/functions on my NL3 now! (mono/legato/poly, pitch bend up/down values)
I guess i'm going to have to rethink how i play certain things.
I have another similar question...is it possible to program a switch to change between mono and legato env modes? I use this a lot when playing bass synth, and it would be awesome to do it seamlessly on the g2 (ie. not via patch settings)
Checking out all the possibilities of the G2 sure takes time away from the playing, yet it's kinda addictive!
Thanks,
Rob |
Audio files: 116
G2 patch files: 317
Posted: Sun May 15, 2011 5:33 pm Post subject:
I don't know really how the legato mode works - it just does not retrigger the envelopes when a new note comes in before the old one was off?
In that case the monokey module seems to do just that on it's gate output; releasing the gate when the last key goes off. _________________ Jan |
RG123
Posted: Sun May 15, 2011 7:47 pm Post subject:
Aha, of course. Thanks for your help! _________________ NEW EP @ WWW.ROBGENTRY.COM |
gosmith
Joined: Apr 06, 2008 Posts: 6 Location: New York City, USA
Posted: Tue Sep 20, 2011 8:10 am Post subject:
Hello Blue Hell, I'm very interested in your trick for getting the MonoKey module to behave monophonically, i.e. the "handful of other modules" that would restrict the output of "Lo" to just one voice. I can isolate one voice using the Voice No. output of the Status module, but the problem is that I don't know which voice is being assigned to the lowest keyboard note at any given moment, so "Lo" only triggers when my lowest note happens to use that voice.
Gordon |
Audio files: 116
G2 patch files: 317
Posted: Tue Sep 20, 2011 8:26 am Post subject:
Oh dear - that reminds me on the Fermat theorem - I've no idea what went through my mind then, it must have looked trivial to me at the time
I'll see if I can think something up .. but the "not knowing which note is in which voice" seems tricky to me too right now ... _________________ Jan |
gosmith
Posted: Tue Sep 20, 2011 8:47 am Post subject:
| Just had a thought, but no time to try it now -- what if I AND'ed the MonoKey's Gate with the Keyboard module's Gate -- the latter is supposed to affect only one voice... |
Tim Kleinert
Joined: Mar 12, 2004 Posts: 990 Location: Zürich, Switzerland
Audio files: 6
G2 patch files: 201
gosmith
Posted: Wed Sep 21, 2011 6:38 am Post subject:
OK, thank you Tim, I think you answered my question, but unfortunately you've also pinpointed a problem that lies either in my G2X or in the OS.
First off, I believe you solved my initial problem by running the Voice # output into the Compare-to-Signal module's B input, and letting the Gate decide whether to pass the resulting logic signal through to the Amp's Gate input. I've never seen the CTS module used in this way -- what does it mean when there's nothing plugged into the A input? What is it comparing B to in this case?
And now the problem: the "Lo" mode doesn't work! Actually, if you disconnect the Vel output from the Amp, then it works, so the real problem is in the Vel output of MonoKey's Lo mode -- no output! Do you notice the same thing on your G2? I have another G2X that I can try it on...
| Stripped-down version of Tim Kleinert's patch, with only the MonoKey mode |
 Download |
| Filename: |
mono_only_tk_106.pch2 |
1.21 KB |
| Downloaded: |
208 Time(s) |
Tim Kleinert
Audio files: 6
G2 patch files: 201
Posted: Wed Sep 21, 2011 7:08 am Post subject:
| gosmith wrote: | | what does it mean when there's nothing plugged into the A input? What is it comparing B to in this case? |
Nothing plugged into the input equals zero. So this module outputs a logic high signal only when the B value is zero (which corresponds to voice #1 from the status module) and a logic low for any value higher than zero (which corresponds to all other voices which we do not want to trigger in this case). I use the module in this manner because the compare modules are of a "=>" (equal or higher) kind (logic high for equal or higher), but I want a logic low for higher. So this is the most efficient way to patch this. Looks a bit strange, I agree.
| gosmith wrote: | | And now the problem: the "Lo" mode doesn't work! Actually, if you disconnect the Vel output from the Amp, then it works, so the real problem is in the Vel output of MonoKey's Lo mode -- no output! Do you notice the same thing on your G2? | Yes. You have just discovered another OS bug.  |
varice
Joined: Dec 29, 2004 Posts: 625 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Wed Sep 21, 2011 12:20 pm Post subject:
| gosmith wrote: | | ...And now the problem: the "Lo" mode doesn't work! Actually, if you disconnect the Vel output from the Amp, then it works, so the real problem is in the Vel output of MonoKey's Lo mode -- no output! ... |
This is a known bug that was never fixed. Ian reported it first here:
http://electro-music.com/forum/topic-8856.html _________________ varice |
Tim Kleinert
Audio files: 6
G2 patch files: 201
Posted: Thu Sep 22, 2011 1:42 am Post subject:
Wow -way back in 2005! I stand corrected.  |
