that vca problem
gammacrew
PostPosted: Tue Mar 05, 2013 1:12 pm    Post subject: that vca problem Reply with quote  Mark this post and the followings unread
Hello
I have tried to make a vca on that 2162 chip. I have used datasheet application as a start, but got weird behaviour - when i power up the circuit i got -10V on vca output (cv and input are not driven by any source). when i disconnect just Vee pin for a second and connect again everything works fine - output = 0V. it does not depend on PSU, i have tried several power sources.
Maybe someone had such problem and solved it?
regards
