Using single patch for multiple Audio In
Page 1 of 1 [3 Posts]
moylando
PostPosted: Tue Dec 06, 2011 10:31 pm    Post subject: Using single patch for multiple Audio In Reply with quote  Mark this post and the followings unread
I've got a patch I like for processing audio in. Right now it's just using In 1, but I'd like to process stereo audio. However, I'd like the patch to respond to the controls for both channels simultaneously. That is, if I adjust the filter cutoff I'd like to to affect In1 and In2 both, like they're 2 notes of the same patch.
Is there a way to spread polyphony across the audio inputs?
ian-s
Audio files: 42
G2 patch files: 617
PostPosted: Tue Dec 06, 2011 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would this do what you want?
splitaudio.pch2
example
 Filename:  splitaudio.pch2
 Filesize:  1.17 KB
 Downloaded:  823 Time(s)
moylando
PostPosted: Thu Dec 08, 2011 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, that seems to work. Thanks for the help.
