SRAM card battery
Page 1 of 1 [2 Posts]
rh2y
PostPosted: Mon Dec 26, 2011 11:32 am    Post subject: SRAM card battery Reply with quote  Mark this post and the followings unread
Rats! I turned on my A6 for the first time in a long while (probably 8 or 9 months) and the internal NiMH battery in my SRAM card had discharged, losing my handmade patches.
That's the first time it's happened, and also was probably the longest time between power-ups on the A6, so I'm not too surprised. I left the A6 on for a while to charge the battery back up and re-formatted the card. A few days later, I checked again, and the card was still good.
So I think it's just a matter of the internal NiMH cell on the card itself went too long without seeing power from the synth.
Just fair warning to others, I guess -- if you've got one of these SRAM cards with an internal rechargeable battery, be sure to turn on your synth from time to time to keep it charged!
Russ
Shameless plug: http://www.whiterose.net/~russ/synth.html
CoolColJ
PostPosted: Wed Dec 28, 2011 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
The SRAM internal rechargeable battery is just there to keep the patches while you change the real battery over.
A good card like the Pretec I have with the recommended OEM batteries like Panasonic should last a while.
My SRAM card was still going strong 10 years later, but I changed the battery over last year. The Voltage on a volt meter was still good, but better to be safe than sorry.
Always go for good batteries, worth the extra.
My Pretetc has a Panasonic BR2325, but they also recommened PAYOVAC BR2325 and a Panasonic CR2025
Niio1
