 Forum index » DIY Hardware and Software » Musical Interfaces
Help with Highly Liquid MIDI THRU Circuit
Page 1 of 1 [4 Posts]
hippoPolice
PostPosted: Sun Feb 12, 2012 6:33 pm    Post subject: Help with Highly Liquid MIDI THRU Circuit Reply with quote  Mark this post and the followings unread
Hi Everyone,
This is my first time posting on electro-music.com.
I was wondering if anyone could take a look at the bread board layout I did for Highly Liquid's schematic of a 5 channel MIDI Thru box.
Here are the schematics:
http://highlyliquid.com/support/library/midi-thru-circuit/
This is what I cooked up:
Am I doing something obviously wrong? I don't have a lot of exp with schematics.
Thank you!
bubzy
Audio files: 47
PostPosted: Mon Feb 13, 2012 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
hi and Welcome to electro-music Smile
what problem are you having with the circuit?
ive only looked very quickly but it seems to be ok.
maybe if you told us whats going wrong we could be more useful Smile
_Richard_ Smile
hippoPolice
PostPosted: Mon Feb 13, 2012 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
ah. well. i'm not exactly sure.
it doesn't operate.
i'm also not so good at using my multimeter so I can't tell where the exact problem is.
glacial23
PostPosted: Thu Feb 16, 2012 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the version of the schematic on Papareil's site, it specifies a 3.3k resistor going to pin 6 of the optocoupler when using a 6n136, rather than the 10k that Highly Liquid's schematic uses.
I know when I build my x0xb0x, I ended up having to use a much lower resistance than the optocoupler/schematic called for - they can be kind of strange sometimes.
glacialcommunications.com
