How to add Effects to External Midi device
Page 1 of 1 [4 Posts]
Parkol
PostPosted: Mon Mar 21, 2011 6:01 am    Post subject: How to add Effects to External Midi device
Subject description: Advice for a sound card.
Hi all.
My question is:
My stuff is Focusrite Saffire, Nord Modular G2 Engine and Logic Pro. Axiom 61… So… I try to explain what I can’t do… I really look for some info but I can’t find about that.
My midi setup is here:
For example, I have a project in Logic
And 4 midi channels(for midi effects and changing patches) and 4 external instrument channels (Nord Modular G2 external midi device, for adding effects).
When I add an effect to 1 of external instrument channels (reverb or flanger or delay etc…), it works for all external instruments channels but I add it to the ONLY one external instrument channel… So, for example if I want to add:
1 channel – only reverb
2 channel – only distortion
3 channel – only flanger
4 channel – only delay
When I play, for example first channel (reverb) – I hear all effects I added to 4 external instruments. Not only reverb, but flanger and etc… I hope you understand. When I play software instruments – it’s OK, but not for my external device…
So all I want is to add effects to channels I choose…
I’ll be very happy if someone helps me.
Thank you.
http://parkol.net/
http://www.myspace.com/parkolmusic
grimley
G2 patch files: 9
PostPosted: Mon Mar 21, 2011 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I assume you have also done the following:
. Connect all 4 physical outputs on G2 to physical inputs on Saffire.
. In Saffire MixControl setup 4 mono inputs to match physical inputs on hardware.
. In Logic external instrument, for each track set the input to be the appropriate Saffire input.
. Set G2 slot 1-4 outputs to 1L, 1R, 2L, 2R respectively.
Sleep Distillery
Apeirophobe
Parkol
PostPosted: Mon Mar 21, 2011 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
http://parkol.net/
Parkol
PostPosted: Mon Jan 23, 2012 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I decided to buy a new sound card with more than 4 inputs and could you advice any?
I am interested in soundcard for about 500 Euro to connect all 4 Nord G2 outputs to 4 soundcard inputs, so I need many inputs and stability.
Now I think about this http://focusrite.com/products/audio_interfaces/saffire_pro_40/overview/, but if you know something better, I would take a look at it. Thank you.
http://parkol.net/
