Pink Noise Signal
Page 1 of 1 [4 Posts]
varice
G2 patch files: 46
PostPosted: Sat Oct 15, 2005 11:24 am    Post subject: Pink Noise Signal Reply with quote  Mark this post and the followings unread
I wonder why the G2 Noise module does not have a pink noise setting?
Here are a couple of simple circuits that can be used generate an approximate pink noise signal.
PinkNoise.pch2
 Filename:  PinkNoise.pch2
 Filesize:  1.27 KB
 Downloaded:  744 Time(s)
varice
Rob
G2 patch files: 109
PostPosted: Mon Oct 17, 2005 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is some more that might be useful to some of you.
1) A digital noise filter that changes the evenly distribution into a bellshaped one.
2) A 'classic' pink noise filter.
3) A noise filter that morphs between pink noise and blue noise.
4) A very cheap in resources filter that is somewhere inbetween pink and white, and enhances the presence of e.g. noise based percussive sounds in a mix.
5) A moderately broad bandpass filter with some slight resonance, not unlike a peak equalizer, but specifically suited for filtering noise. In the patch it is chained after filter 3) to combine into a versatile variable noise filter.
Noises.pch2
Five example types of noise filters.
 Filename:  Noises.pch2
 Filesize:  3.25 KB
 Downloaded:  700 Time(s)
varice
G2 patch files: 46
PostPosted: Tue Jan 31, 2012 1:09 am    Post subject: Pink Noise Test Patch Reply with quote  Mark this post and the followings unread
Here is a patch that produces one of the best pink noise spectrums that may be possible with the G2. It has 33 white noise sources feeding 33 6dB low pass filter bands set at 1/3 octave frequency cutoff intervals from 13.75Hz to 21.1kHz with each higher frequency band attenuated by approximately 1dB (resulting in the required overall -3dB per octave low pass filter slope). Separate white noise sources were used for each filter band to decouple what appears to be a slight signal phase interaction between each band when using a single white noise source. Thankfully the G2 software programmers did a good job of making sure that each noise module in a patch is seeded differently resulting in a different output from each instance. Wink
This patch is too DSP hungry and bloated to be of practical use as a building block noise source in a normal synth patch. But it is useful for the generation of a very accurate pink noise signal for test purposes.
PinkTest.pch2
 Filename:  PinkTest.pch2
 Filesize:  6.24 KB
 Downloaded:  138 Time(s)
varice
varice
G2 patch files: 46
PostPosted: Tue Jan 31, 2012 1:37 am    Post subject: A Pink Noise Tweak Reply with quote  Mark this post and the followings unread
Here is another version of a simple patch to generate an approximate pink noise signal. This one has an EQ added to boost the mid frequency band for a better spectrum.
A working example is used in the “mm 2 Osc VM” patch posted here:
http://electro-music.com/forum/topic-9258.html
Check out Variation 6 for a high resonance filter sweep of the pink noise source. Cool
Pink Noise 2.pch2
Pink Noise building block version 2
 Filename:  Pink Noise 2.pch2
 Filesize:  1.22 KB
 Downloaded:  173 Time(s)
varice
