Nord Rack 2 OS upgrade and output jacks
Page 1 of 1 [5 Posts]
paugui
PostPosted: Thu Feb 23, 2012 4:00 pm    Post subject: Nord Rack 2 OS upgrade and output jacks Reply with quote  Mark this post and the followings unread
Hi
I got a Nord Rack 2 today.
Unfortunately it has a small problem - the outside part of Output A is broken (it still works, but I would like to get it replaced).
Anyone here knows where I find can the jacks that were used on the Nord Rack 2, so that it'll look just like new?
Are these a relatively normal piece (if so can someone give me reference of it?).
I also noticed the OS in it is version 1.02.
Is it still possible to upgrade to the latest version?
Shall I just contact Clavia for that?
Thanks in advance,
Best
Paulo
Akai EWI3020/3030m / Alesis Fusion / Cheetah MS6 / Clavia Nord Modular G1/G2X / Creamware Noah, Scope / EMU E6400U, P2000, XL7 / Ensoniq Fizmo / Hartmann Neuron / Ibanez AD202, DM2000 / Kawai SX-240 / Korg 05R/W, A1, DSS1, EMX1, Legacy Collection, Oasys PCI, P6, P800II, SDD3000, Trident, Triton Pro, Zero 8 / Novation SBS, AS / Pearl DRUM-X / Roland D550, MKS80, R880, SRE555, VariOS, V-Synth / Soundart Chameleon / Symetrix 606 / Teisco S110F / Waldorf Blofeld kbd, mQ / Yamaha A5000, AN1x, CS5/15, FS1r
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Feb 23, 2012 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
For both items I would contact Stockholm.
The jack Outputs are mounded on the motherboard, so it will be best to repair it at a service station, e.g. the distributor.
The OS update [1.06] is on a e-prom chip. Clavia has to provide this (if they will make a run, someday...)
Send your request using the feedback form on thier site (not the service one!)
Wout
paugui
PostPosted: Thu Feb 23, 2012 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I checked again and it seems the OS is the last one...
I guess I made a mistake...
I'll try to check with them about the piece for the output jack, but I hope it won't be necessary to send it to the distributor to repair, cause that's out of question...
It would be way to expensive to send it to Spain for repairs considering it still works properly... and I don't trust the distributor at all, due to the problems I had with them during the repairs of my G2X...
But since I only need a the same piece, I hope that won't be necessary...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 24, 2012 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
paugui wrote:
... But since I only need a the same piece, I hope that ...
Better to check with Clavia first.
Wout
paugui
PostPosted: Fri Feb 24, 2012 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'll do that Smile
And thanks lot for your help Smile
Best
Paulo
