deadbeat
Posted: Sun Feb 19, 2012 4:08 am Post subject:
Water & Bird Box Subject description: one year child gift !! |
Hi all !
I want to share with you this little noise box i made for my friend's child birthday (one year !!). It gives a messy sound, but can create beautiful artefacts...
Here's the schematic ! I had best results with very little caps ( 0,001uf & 0,047 for the clock).
It's based on a cd4093 & a cd4094 ( i don't really know if i used it the right way...).
Let me know what you think about it, and ideas to improve it are welcomed !!
11.98 KB |
| Viewed: |
86 Time(s) |
82.91 KB |
| Viewed: |
57 Time(s) |
_________________ http://h.a.k.free.fr/
http://virb.com/dead_beat
http://virb.com/bend_over_boysfriends |
JingleJoe
Joined: Nov 10, 2011 Posts: 789 Location: Lancashire, England
Posted: Sun Feb 19, 2012 9:12 am Post subject:
Just looked up the 4049N but it appears you are using something else entirely, the only 4049 I can see is some logic buffers.
Would it be possible to get some sound too? _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Green Dungeon Alchemist Laboratories |
Psyingo
Posted: Sun Feb 19, 2012 12:13 pm Post subject:
| JingleJoe wrote: | Just looked up the 4049N but it appears you are using something else entirely, the only 4049 I can see is some logic buffers.
Would it be possible to get some sound too? |
4094. |
deadbeat
brock
Posted: Sun Feb 19, 2012 5:21 pm Post subject:
Re: Water & Bird Box Subject description: one year child gift !! |
| deadbeat wrote: | | ( i don't really know if i used it the right way...) |
There's a wrong way to use a part in a Lunetta? I think that if it makes sound, you've found a right way. |
JingleJoe
Posted: Mon Feb 20, 2012 3:17 am Post subject:
| deadbeat wrote: | i don't really understand what you mean Jingle jOe... sorry.... |
oh I read the number wrong on the IC, but I also requested some audio samples of this device. _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Joined: Jan 15, 2011 Posts: 188 Location: Montreal, Canada
Posted: Mon Feb 20, 2012 8:57 am Post subject:
| I would have liked to hear it too. I am intrigued by electronic "water sounds", but right now I don't have a 4094 to build the circuit myself. Ah well, not sure when I can get to the electronics store... maybe I'll pick up a bunch of CMOS I still don't have. |
deadbeat
Posted: Wed Mar 07, 2012 5:10 pm Post subject:
OK, I finally managed to get to the electronics store and buy a 4094. I built the circuit, but instead of photo-resistors, I used pots. The sound was barely audible, so I just used one of the outputs of the 4094, bypassing the diodes & LEDs. All the outputs had the same sound, as far as I could tell.
Maybe I read the schematic wrong? The output is connected to the vertical line which connects the cathodes of the diodes? Pin 1 of the 4094 is connected to pin 15? Pin 10 and 11 of the 4093 are connected to pins 2 and 3, respectively? |
deadbeat
Posted: Wed Mar 07, 2012 10:26 pm Post subject:
Yes, i realized that all the outputs were the same...
I've tried several condensator values, little values are best... And i've sent the output bus to a lm386, in order to feed a little speaker...
It's my first design with a cd4094, i think it's a bit messy, but i'll go back to it as soon as i can, i think it can be improved.
I've never tried with pots, maybe it wouldn't work the same way... DOn't know.
But it's a really messy noise toy ! _________________ http://h.a.k.free.fr/
