Vulcan mod: Ribbon cable upside-down?
alwaysnew
PostPosted: Fri Mar 30, 2012 8:24 pm    Post subject: Vulcan mod: Ribbon cable upside-down? Reply with quote  Mark this post and the followings unread
So I just got a Vulcan Modulator and an Intellijel Mind Meld. Great! The only problem is that the Vulcan has a ribbon cable-ending that is upside-down. It won't fit into my uZeus the right way, red stripe to red stripe (and yes, I've checked to see if the ribbon is correctly attached concerning the red stripe).
I could fit it upside down (and fry the unit) since the little pointy black piece of plastic is on the side that fits into the uZeus the wrong way but as you might guess I don't want to do that.
So what do I do? I'm I really meant to take a file and remove the pointy piece? Sounds a bit primitive. It's all very weird...
Also: Anyone knows if Mind Meld has a current draw? Can't find any info on it but still, it has a ribbon cable coming out of it!
