  bingsatellites Mostly Ambient
tone control / filter for theremin ?
Page 1 of 1 [5 Posts]
low_rider
PostPosted: Fri Mar 23, 2012 12:46 pm    Post subject: tone control / filter for theremin ? Reply with quote  Mark this post and the followings unread
I am working for a couple of weeks on a theremin which is based around an MCU and generates the audio by digital means. I would like to add some kind of tone control or filter. Can anyone suggest anything? Somehow I got completely lost here! Smile
DrJustice
PostPosted: Sun Mar 25, 2012 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you thinking of implementing a digital filter in the MCU, or an analogue one after the DAC?
DJ
low_rider
PostPosted: Sun Mar 25, 2012 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry I was not clear enough on this... I would like to implement an analog filter...
DrJustice
PostPosted: Sun Mar 25, 2012 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, without anything more specific, you may as well start by looking at these two : simplified moog type filter and Most simple VCF on earth. Those are fairly simple with low a component count, and may be good for starting out. Our DIY section contains lots of project for filters - you may want to look around and/or search some here.
Maybe other members will post some good 'first-timer' filters here?
DJ
DrJustice
PostPosted: Wed Mar 28, 2012 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I'd add: if you're interested in a tone control as well / instead, a google search for "Baxendall tone control" should give you many variants to pick from.
DJ
Niio1
