boss dr-110 trig mod
Page 1 of 1 [6 Posts]
damj
PostPosted: Tue Apr 17, 2012 11:42 am    Post subject: boss dr-110 trig mod Reply with quote  Mark this post and the followings unread
I am new here and kind of new with electronics. I am modifying a dr-110 and I want to add both trig in and trig out for each sound.
As I understood it the dr-110 uses s-trig and I want to use normal gate.
The only idea I have figured out is to cut the cable between the analog and digital board for each sound and add a s-trig to v-trig converter between the out jack and the digital board and a v-trig to s-trig converter between the in jack and the analog board.
It doesn´t seem like the smartest solution... I have to build a lot of converters and I need to patch it to use the internal sequencer.
Surly someone here can come up with a better solution
richardc64
Audio files: 25
PostPosted: Wed Apr 18, 2012 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't have to be complicated. Two CD4049 inverting buffers should do it.
All but one of the '110 voices have the same triggering mechanism: a PNP transistor biased "off" until a low-going pulse from the uC pulls the base down. Simply invert the uC pulse for an active-hi trigger out, and invert your external triggers (which you are calling "gates",) and connect that to the PNP bases. Duplicate the top left circuit three times for OH, CH and CY and that's one 4049.
The Snare is a little trickier because it's made up of three sounds: VCA'ed noise, a triggered ringing oscillator, and the trigger itself as "Impact." The added 33k and .002 cap handle the external Impact portion. BD (Kick) is the simplest to deal with.
CLap is a special situation because it isn't just one trigger, but a burst of three, plus another some time after them. You decide how you want to deal with them.
You WON'T be able to fit this inside the '110 case.
 Filesize:  17.66 KB
 Viewed:  35 Time(s)
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
roglok
PostPosted: Thu Apr 19, 2012 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, Richard! I have a DR-110 with a broken CPU board lying around and never managed to trigger the snare properly...
It would be awesome to find a simple way (preferrably analog) to make the timing and amount of clap trigger-bursts adjustable from the front panel - Simmons Clap Trap style...
When I find the time, I'm gonna get back to this and probably rack it up as a euro module...
richardc64
Audio files: 25
PostPosted: Thu Apr 19, 2012 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
One thing...the external triggers should be of similar duration to the original: 1mS to no longer than 5mS or so. As the trigger gets longer, the inherent "thump" of the one-transistor VCAs becomes more noticeable. Also, the ringing, damped oscillators of the Snare shell and Bass will trigger on a falling or rising edge. Make the trigger(s) too long and you'll get two sounds per trigger, instead of only one -- which now that I think of it might be useful!
To ensure that external triggers produce short pulses you could put a cap before the 4069 input, selecting the value for that and the pull down resistor to produce a suitable duration. I use this: http://hughestech.com/rc_calculator/
Umm...I have an idea that would do that, but don't want to say anymore until I actually try it -- and there's no telling when THAT would be. Maybe saying that it would use a CD4538 dual retriggerable monostable multivibrator and a gated schmitt oscillator is enough of a hint for someone else to try it.
damj
PostPosted: Thu Apr 19, 2012 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Richard, it does not look to difficult, I think (hope) I can get it to work...
roglok
PostPosted: Thu Apr 19, 2012 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right! I remember this from the 808 BD clone. The triggers from my 606 would retrigger the kick, because they have a small negative peak after the initial falling edge...
I got the fix from Eric Archer's page, which is basically the same as your suggestion:
