FaschingsPrinz
G2 patch files: 4
Posted: Tue Apr 03, 2012 12:45 am Post subject:
"circuit diagram" for Nord Modular G2 ? Subject description: broken USB-connector ? measuring where / what / how ? |
Dear friends,
Now it struck me too!
No USB-connection!
Nord G2 Keyboard 1.62 on a Windows XP SP3 laptop.
I read here in this forum that re-soldering the USB-connector may help. Since I´ve never done a thing like that, I brought the G2 to a colleague of mine who´s capable of doing things like that; But he´s no musician and has never had something to do with synthesizers.
He told me he already measured everything but can´t find any broken connections. He connected the G2 to his computer, but nothing happened too (no query for required drivers etc.).
But to be sure he asked me if I can bring him a circuit diagram so he can dig deeper with his measuring without having to guess so much.
Does anybody possess a circuit diagram of a Nord Modular G2 (keyboard) and would be willing to send it to me ?
THANX a LOT in advance,
Markus
keeping my fingers crossed! _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
But if I have an idea, and you have an idea, and we exchange ideas, then we BOTH have TWO ideas."
G.B.SHAW |
Roland Kuit
Joined: Sep 29, 2003 Posts: 995 Location: The Hague, The Netherlands
G2 patch files: 125
Posted: Tue Apr 03, 2012 1:17 am Post subject:
Re-soldering is for a broken USB. Or worn out one. I have to do this shortly. Sometimes it seems if a routine is stuck in the G2. A way is to 'reset' the thing by pressing 10 times on/off. Hope this helps. _________________ Roland Kuit
http://rolandkuit.com/ |
FaschingsPrinz
G2 patch files: 4
Posted: Tue Apr 03, 2012 8:48 am Post subject:
.. aah, .. "the IT crowd"-trick ? sun-spots anybody?
No, I haven´t done that yet.
Will try it, but will also try [PERFORMANCE MODE]+ [PATCH LOAD] during startup, which I found here somewhere too.
I saw you had the same problems once upon a time.
How did you solve it ?
Markus _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
G.B.SHAW |
Roland Kuit
G2 patch files: 125
Posted: Tue Apr 03, 2012 9:39 am Post subject:
I had it 2 times and yes, it solved my problem. Jan Punter tipped this off. Good luck! _________________ Roland Kuit
Estarriol
Posted: Wed Apr 04, 2012 9:31 pm Post subject:
As far as I know, there are no circuit schemes of NMG2. Maybe the guy at Encore electronics who made a new expansion board could make one coz' he had no problem examining the original expansion.
Dyuing USB chips is a common problem. What's worse, the corresponding USB chip "ISP1181BDGG" is marked as obsolete at Mouser, so finding one could be a problem. |
FaschingsPrinz
G2 patch files: 4
Posted: Wed Apr 04, 2012 11:41 pm Post subject:
Estarriol wrote: | Quote: | | Dyuing USB chips is a common problem |
Is there a way to find out if it´s my USB-chip that died, or something else ?
How can I separate the possible sources for my broken USB-connection ?
Is there an indicator which will tell me (measuring) that it´s the chip that died ? _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
G.B.SHAW |
voltage control
Joined: Mar 11, 2010 Posts: 5 Location: another world
Posted: Thu Apr 05, 2012 8:33 am Post subject:
| You can measure for continuity between the 4 connectors in the usb port and points on the circuit board that the corresponding usb port pins lead to. If these connections prove to be in order, and your computer does not "see" the G2, there is a good chance that the usb chip will have to be replaced. |
Baby
Joined: Apr 24, 2006 Posts: 45 Location: Laos Angeles
General Elektrick
Joined: Apr 06, 2004 Posts: 248 Location: Berlin/Germany
Posted: Fri Apr 06, 2012 7:18 am Post subject:
I had a lightning strike destroying my USB connection on the G2. I got help for around 250 € here:
http://www.synthesizerservice.de/
For this prize they replaced a led display as well which did not lit up. Pretty fair price. recommended by me...
Greets,
Chris aka general elektrick _________________ Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage. |
Estarriol
Posted: Thu May 03, 2012 6:32 am Post subject:
| A circuit diagram for NMG2 is a big thing. It basically requires reverse engineering the hardware, which equals time & skill. I'm currently trying to reverse G2 display board schematics because it has no DSP on board AFAIK. But it still requires bill of materials to be made, all of the electrical connections between components on the board (node list, sometimes called a net list) to be identified and so on. |
