OW
Posted: Mon May 14, 2012 8:10 am Post subject:
Modular Power supply |
I'm just about ready to start ordering parts for a modular I am building. It's only going to be a 22U modular.
The power supply I require is +/- 15 V. I don't want to use a wall wart, as I want to mount a transformer inside the case. I'm also looking to build a power distribution board.
Can anyone point me in the direction of one?
Thanks! |
bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
OW
Posted: Mon May 14, 2012 8:57 am Post subject:
Thank you for the reply!
I was looking for something that used multipole connectors via a distribution board so I could connect it to all my modules. |
marvkaye
Posted: Mon May 14, 2012 10:28 am Post subject:
I like Ray Wilson's (MFOS) LM317/337 adjustable supply, very robust, plenty of power. Hooking its outputs up to a distro board made from stripboard and MTA connectors would be pretty simple. FWIW
<marv> |
fluxmonkey
Posted: Mon May 14, 2012 7:35 pm Post subject:
i'm an avid DIYer, but i swear by used PowerOne open frame linear PSs... ebay or th local surplus outlet, i usually can pick 'em up for around $25 or so, which is cheaper than i could build and better quality.
ken stone has distribution boards, CGS73 for euro CGS74 for .156" a la MOTM. http://www.cgs.synth.net/pcb/index.html _________________ www.fluxmonkey.com |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Tue May 15, 2012 3:23 am Post subject:
There's a thread here,
http://electro-music.com/forum/viewtopic.php?highlight=psu&t=29075
which documents my build of a +-15V precision PSU. It's in a rack box, but you could probably put the same thing together on the inside wall of your modular. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Osal
marvkaye
Posted: Tue May 15, 2012 6:42 am Post subject:
| Osal wrote: | Hello,
I recommend my ps2.
It is much better than the ones based in standard regulators Lm317 and 78XX.
It can output +15V/-15V from a 30VCT transformer instead of a 36VCT transformer because it uses the low dropout regulator MIC2941. This translates in a much less power dissipation, thus more small heat sink or/and lower temperature operation, increasing durability and reliability.
Furthermore, the PCB is designed to be attached to a rear panel with a more neat result. |
I like it... gonna have to give it a try. Do you have PCBs or layout available? This is something I, for one, would purchase. Thanx for sharing.
<marv> |
Osal
Posted: Tue May 15, 2012 7:03 am Post subject:
| marvkaye wrote: | | Osal wrote: | Hello,
I recommend my ps2.
<marv> |
Thanks for your interest marv, I will go forward with this project again in a month or so. Then I will upload the PCB layout, the parts placement, and a BOM to be accessible for every one. However if you are in a hurry I can send you the prototype pcb layout, please send a pm if you are interested.
About to have a ready PCB... yes I want to... but this will take a little more time. _________________ electronic-sea.net |
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
Posted: Tue May 15, 2012 7:51 am Post subject:
I built the Oakley PSU. Uses a uA723 regulator for the positive and a precision opamp for the negative rail and works great.
Oh, and the current sensing is a nice feature too.  _________________ Weblog!
Kits for synthesiser modules in Europe |
marvkaye
Posted: Tue May 15, 2012 8:45 am Post subject:
| Osal wrote: | Thanks for your interest marv, I will go forward with this project again in a month or so. Then I will upload the PCB layout, the parts placement, and a BOM to be accessible for every one. However if you are in a hurry I can send you the prototype pcb layout, please send a pm if you are interested.
About to have a ready PCB... yes I want to... but this will take a little more time. |
I'm not in any hurry, Oscar, as I'm pretty well PS'ed up at the moment, but it would be a great thing to have in the future. Whenever you get around to it is fine by me.
Regarding your distribution board.. just a thought, but if you eliminated the top center standoff you could loop the main + bus around the top and connect into the column's + buses, eliminating those jumpers across the bottom. Again, just a thought......
<marv> |
Osal
Posted: Tue May 15, 2012 9:19 am Post subject:
| marvkaye wrote: |
I'm not in any hurry, Oscar, as I'm pretty well PS'ed up at the moment, but it would be a great thing to have in the future. Whenever you get around to it is fine by me. |
OK, I let you know.
| Quote: | | Regarding your distribution board.. just a thought, but if you eliminated the top center standoff you could loop the main + bus around the top and connect into the column's + buses, eliminating those jumpers across the bottom. Again, just a thought...... |
Thanks for the suggestion
The center standoffs are required to avoid that the PCB flex when inserting the connectors.
Notice that I can not run any trace in the top due it would cut the grounds of each column.
I placed the connectors like this to avoid long buses. I tried to achieve the lower impedance possible in all the paths.
The ideal would be a double sided PCB, with one of the planes dedicated to the ground. _________________ electronic-sea.net |
seaweedfactory
Joined: Apr 12, 2006 Posts: 74 Location: Portland, Maine
Posted: Wed May 16, 2012 10:30 am Post subject:
I'll second the above post about using a Power One supply.
I've used the Power One HBB-15-1.5-A model for each cabinet I build. It's a 15V+/- supply that puts out up to 1.5As, which should be plenty for 22U worth of modules. They are very cheap on Ebay as salvage. _________________ Blog: http://seaweedfactory.blogspot.com/
Youtube: http://www.youtube.com/user/SeaweedFactory |
LektroiD
Joined: Aug 23, 2008 Posts: 960 Location: Scottish Borders
Posted: Wed May 16, 2012 11:47 pm Post subject:
| Not wanting to mess too much with mains electricity, I ripped my PSU out of an old Crumar synth. It has ±5 / 12 & 15V outputs. Which is perfect as the synth I'm making uses a variety of different boards with different power requirements. I power my 4 oscillators separately (to avoid any interference from other modules), via a MFOS 12V wall wart supply. And unless you have a very strong PSU, I'd recommend powering oscillators separately to anyone who wants added stability. |
LektroiD
Posted: Thu May 17, 2012 3:46 am Post subject:
| LektroiD wrote: | | Not wanting to mess too much with mains electricity, I ripped my PSU out of an old Crumar synth. It has ±5 / 12 & 15V outputs. Which is perfect as the synth I'm making, since it uses a variety of different boards with different power requirements. I power my 4 oscillators separately (to avoid any interference from other modules), via a MFOS 12V wall wart supply. And unless you have a very strong PSU, I'd recommend powering oscillators separately to anyone who wants added stability. |
DES
Audio files: 6
Posted: Sun May 20, 2012 11:08 am Post subject:
Looks like your PSU was well on its way to completion. How did it turn out? I tried the link to the schematic and the link was dead. I didn't see any schematics elswhere on the site. Do you only get acces to them if you buy the PCBs? _________________ Dave
www.davesneed.com
www.myspace.com/desneed |
