Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Sun Jul 08, 2012 4:07 am Post subject:
Using rotary encoder switches with Arduino |
Does anyone know how to use rotary encoders reliably with Arduino? _________________ ACHTUNG!
Joined: Apr 03, 2004 Posts: 19593 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Jul 08, 2012 5:54 am Post subject:
This is what I used on a PIC ... not too efficient but it did the job
| Code: | code LpIntTMR3IF ( -- ) // Interrupt code
; [ TMR3IF timer 3 overflow interrupt, must be cleared in software ]
; [ Interrupts every approx. every 100 us ]
SetBSRDefault ; // Assure correct RAM bank
bcf pir2, TMR3IF ; // Clear the interrupt condition
; // reload the timer
movlw (( <@" tmr3_time">) >> 8) & 0xff
movwf tmr3h
movlw (( <@" tmr3_time">) >> 0) & 0xff
movwf tmr3l
call <@" _CollectRawInputs"> ; // Get physical inputs into wreg bits 0,1
; // Decode rotary, no debouncing used
movlw 0x03 ; // Isolate old state
andwf <@" RotaryState">
rlncf <@" RotaryState"> ; // shift it left over two bits
movf <@" InpStatus">, w ; // Or in new state
andlw 0x03 ; // as the low two bits
iorwf <@" RotaryState"> ; // to be kept for the next round
jr_f <@" RotaryState"> ; // Dispatch on old/new combination
bra t3_rot_done ; // 00 -> 00 nothing
bra t3_rot_up ; // 00 -> 01 up
bra t3_rot_dn ; // 00 -> 10 dn
bra t3_rot_done ; // 00 -> 11 nothing
bra t3_rot_dn ; // 01 -> 00 dn
bra t3_rot_done ; // 01 -> 01 nothing
bra t3_rot_done ; // 01 -> 10 nothing
bra t3_rot_up ; // 01 -> 11 up
bra t3_rot_up ; // 10 -> 00 up
bra t3_rot_done ; // 10 -> 01 nothing
bra t3_rot_done ; // 10 -> 10 nothing
bra t3_rot_dn ; // 10 -> 11 dn
bra t3_rot_done ; // 11 -> 00 nothing
bra t3_rot_dn ; // 11 -> 01 dn
bra t3_rot_up ; // 11 -> 10 up
bra t3_rot_done ; // 11 -> 11 nothing
t3_rot_up
incf16 <@" RotaryCount">
bra t3_rot_done
t3_rot_dn
decf16 <@" RotaryCount">
; // Fall through to rot_done
t3_rot_done
; // Rotary done, fall through
_Int_T3_Done
return ; // B/ ---->
endCode
_________________ Jan |
Posted: Sun Jul 08, 2012 11:33 am Post subject:
Thanks Jan.
How did you wire the encoders up to the PIC? _________________ ACHTUNG!
Audio files: 116
G2 patch files: 317
Posted: Sun Jul 08, 2012 12:01 pm Post subject:
Pullup resistor from each input pin to Vcc, and each switch shorts it's input pin to ground when making contact. _________________ Jan |
Joined: Aug 08, 2009 Posts: 556 Location: Upstate New York USA
Audio files: 151
