Gaetano_AU
Posted: Wed Jul 25, 2012 8:40 pm Post subject:
Ultimate VCO Instabilities |
I meant to post this ages ago but forgot. There was a weird drift problem with the Ultimate VCO's, which I noticed. The VCO's seem to get affected by random noise, which I suspected was (obviously) the noise generator, but it was not. The problem is that the 3 VCO Sync inputs need to be grounded when not in use, which they are not by default in my unit as I use banana sockets; otherwise they pick up stray voltages. I tried various simple solutions, but they screwed with the pitch and sync etc. You can just use switched jacks or a switch to ground or a triple banana lead with a ground on one end and plug them all into ground when not in use, problem solved.
To check if you have the same problem just touch wires from the grounded front plate or 6.5mm sockets to all of the Sync inputs to see if they are more stable. I would be interested if anyone else has had this problem. |
iopop3
Joined: May 28, 2010 Posts: 95 Location: Malmö, Sweden
Posted: Thu Jul 26, 2012 11:54 pm Post subject:
The sync input is already pulled down via the 100k resistor going to ground (R27 on VCO-1), so in theory it should not be any problem.
This is a longshot, but maybe the pull down resistor needs to be closer to the bananajack?
Im in the process of fixing a new and dedicated PSU for my SL, will make some tests when that is sorted. |
Gaetano_AU
Posted: Fri Jul 27, 2012 12:08 am Post subject:
| I thought that and tried it already, as I have used pull down resistors for other things with no problem, I even tried different values. I also tried shielded cable on these sockets, but there were still stray voltages. Grounding them when not in use seems to be the only solid solution. You can see the drift on an oscilloscope, but ground them when not in use and they are very stable, actually surprisingly so. This drift is not a criticism of these MFOS units however, I would recommend them to anyone. I am thinking of designing bigger front plates for mine anyway, and if I do I'll just put a solution on there like three switches (I have a few spare). Still, if you do not have the same problem I would be interested to know why, even the AC centre tapped plug-pack I use for the power supply, is external to minimise any stray hum and noise. |
