 Forum index » Instruments and Equipment » Ableton
Questions about Live
Page 1 of 1 [5 Posts]
Inventor
Audio files: 256
PostPosted: Mon Jun 25, 2012 2:17 am    Post subject: Questions about Live Reply with quote  Mark this post and the followings unread
I downloaded a 30 day trial of Live for Mac OSX and I'm running it on Lion. I'm just getting the hang of the basics. Find midi track, put here. Find instrument put there, press play looking button hear sound.
OK, but I want to add vocals and morph my voice and stuff. I also want to use OSCulator with my WiiMotes. How do I do these things?
Les
cappy2112
PostPosted: Thu Jul 26, 2012 1:27 pm    Post subject: Re: Questions about Live Reply with quote  Mark this post and the followings unread
Les
Admins- can we get an Ableton forum- hopefully to stimulate more discussions like this.
Thanks
RFBB
PostPosted: Thu Jul 26, 2012 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les-
To add a vocal track, create an audio track and make sure you to change from auto to monitor (in - I think). Once you have recorded the track, turn monitor off and drag effects to that channel. You could also create several audio tracks (with multiple effects) and send the original vocal track to them. Each audio track will ask you where the audio is coming from and going to.
As far as the Wiimotes, they will connect via Bluetoothe. I've never used that program as I was using GlovePie back in the day when we first discovered Wiimotes could be used as controllers. Regardless, Abe will recognize them and you simply select the parameters and so forth. Pretty straight forward.
"Oh, it's yours? Then go ahead and kick the shit out of it..." as said to Michael Victor by Howard Moscovitz 06/05/05
M.Peck
www.mpeckmusic.blogspot.com
www.reverbnation.com/echotomb
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jul 30, 2012 2:22 pm    Post subject: Re: Questions about Live Reply with quote  Mark this post and the followings unread
Ok, done, moved this there, will move some more Ableton stuff to here as well.
Ni-Kulo
PostPosted: Thu Aug 09, 2012 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
audiotrack with the vocals, and than insert one of the hundreds audio effects there are!
you also can hotswap the effects to "skip" them through faster!
ch33rs!
~ Ni-Kulo § Taurin ~
