 Forum index » Clavia Nord Modular » g2ools utilities
G2ools GUI beta 0.1, for Windows
Page 1 of 1 [19 Posts]
cappy2112
PostPosted: Tue Dec 25, 2007 6:59 pm    Post subject:  G2ools GUI beta 0.1, for Windows Reply with quote  Mark this post and the followings unread
Hello Everyone and Merry Christmas!
I know I'm late getting this out, but at least it's out. My apologies. Embarassed
Attached is the GUI for the G2ools converters, for Windows.
Depending on the feedback and bugs, I will also put together a version
for the MAC. I'm Windows developer by profession, so working on the MAC is mostly uncharted territory for me.
There is a readme file inside of the zip, and hopefully it is clear enough.
If not, let me know.
You MUST have the G2ools already installed (and working).
You do NOT need to have Python installed to use this on Windows.
The GUI is not a new version of the G2ools converter, it's just a user interface.
This has only been tested on Windows XP, SP2, so if you are using any other version of Windows and have problems, let me know.
Known problems with beta 0.1
1, If you select the NM2g2 converter and use a directory without patches or with DX7 patches, the GUI calls the converter, but never returns.
2. When using the DX converter there is a long lag from when you start the converter until you see the converted patches in the list box.
G2oolsGUI.zip
 Filename:  G2oolsGUI.zip
 Filesize:  6.25 MB
 Downloaded:  638 Time(s)
gomidas
G2 patch files: 6
PostPosted: Wed Dec 26, 2007 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's never too late... Smile
Thank you very much for this, greaT JOB CAPPY2112, you work ten times faster than clavia do for their os... Laughing
cappy2112
PostPosted: Wed Dec 26, 2007 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. I assume. It's working ok for you. There are still a few problems to fix, but I was able to convert about 10 subdirectories full of patches (about 100 patches or so, total), without any problems.
I know it's got a crude look & feel, but that can be improved over time.
I wouldn't say I'm ten times faster than Clavia, considering I started on this project about 9 months ago- then stopped Wink
Tom_1970
PostPosted: Thu Jan 03, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Great enhancement!!!
It works great on the patches I converted.
The only 'problem' is the display in some of the boxes in the interface, but that's hardly a problem for me.
I haven't done any DX conversions yet, but I will try later this day.
Great job. Thanks cappy2112.
Regards
Tom
cappy2112
PostPosted: Thu Jan 03, 2008 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Regards
Tom
Thanks. Would you elaborate on what you mean by "the display in some of the boxes"?
dxmat
G2 patch files: 8
PostPosted: Thu Jan 03, 2008 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Work great, some box-display problem (see yellow arrows).
 Filesize:  56.87 KB
 Viewed:  345 Time(s)
cappy2112
PostPosted: Thu Jan 03, 2008 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
dxmat wrote:
Work great, some box-display problem.[/img]
Thanks.
Are you referring to the box in the upper right that's grayed out (the one labeled TBD) ?
That's intentional. That's there as a reminder for me. TBD means To Be Done (not Tony's Been drinking) Wink
I may be adding something there in the next release.
dxmat
G2 patch files: 8
PostPosted: Sat Jan 05, 2008 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
No.
See new uploaded screen on my previous post.
cappy2112
PostPosted: Sun Jan 06, 2008 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
No.
Thanks. This is the kind of feedback I need.
Does anyone else see these graphics oddities on their systems?
Oddly enough, I don't see these issues on my system, but I have a few custom setting under Visual Effects in control panel turned on. Most are disabled to help maxmise performance. These settings sometimes affect how graphics appear, and is controlled by the OS.
For example- all of the square boxes in the GUI, have rounded corners on my system. This is something that is definitely controlled by the Visual Effects settings in Ctrl Panel
I will see if there's something I can do to make these issues appear on my system
Tom_1970
PostPosted: Mon Jan 07, 2008 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I wasn't able to react earlier, but dxmat describes the issue I mentioned in my post.
It's jus a minor thing to me, because ist works perfect when it comes to the actual conversion of patches.
Regards
Tom
cappy2112
PostPosted: Mon Jan 07, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Regards
Tom
Thanks for the feedback.
When you run it on your system, do the group boxes have square corners or rounded corners?
Tom_1970
PostPosted: Tue Jan 08, 2008 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Square
cappy2112
PostPosted: Tue Jan 08, 2008 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Tom_1970 wrote:
Square
Would you try this? Enable the visual styles in Ctrl Panel, and see if the issues you mentioned change.
thanks
 Filesize:  100.62 KB
 Viewed:  303 Time(s)
Tom_1970
PostPosted: Wed Jan 09, 2008 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Cappy,
It already was enabled on my system.
I disabled it....no change
I enabled it again....still no change.
I guess I am not to helpfull Wink
cappy2112
PostPosted: Wed Jan 09, 2008 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tom_1970 wrote:
Hi Cappy,
You've told me what I needed to know, so that is helpful.
Are you running XP or Vista?
Tom_1970
PostPosted: Thu Jan 10, 2008 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I am runnig Windows XP (SP 2).
I will give it a try on my studio laptop. If it behaves different I let you know.
Regards
Tom
eposk
PostPosted: Fri Jan 11, 2008 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!!!!!!!!!!!!!!!!!!!!!! yes!
aMUSEd
PostPosted: Thu Aug 23, 2012 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Could really do with a Mac version of this or something like it.
http://fingermarks.co.uk/music.htm
cappy2112
PostPosted: Mon Aug 27, 2012 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check your PM.
I think the website isn't users notifying of PMs again.
There are PMs in my sentbox from over a year ago
