  bingsatellites Mostly Ambient
SYNCING THE MIDI CLOCK OUT TO THE IN ON A DRUM MACHINE??
Page 1 of 1 [3 Posts]
zdogtru2
PostPosted: Sat Sep 01, 2012 1:10 pm    Post subject: SYNCING THE MIDI CLOCK OUT TO THE IN ON A DRUM MACHINE??
Subject description: can anyone offer some advice on this?
had an A6 question and I thought I would see if you have a quick answer? Im trying to use the A6 as a Midi clock Master to a drum machine Midi Slave. Is there a certain software in global setting I have to configure in order to do this? I cant seem to have any luck with it so far. thanks all,
Mefistophelees
PostPosted: Sun Sep 02, 2012 12:18 pm    Post subject: Re: SYNCING THE MIDI CLOCK OUT TO THE IN ON A DRUM MACHINE??
You can send the clock out.
Press sync/mod
on the right hand side of the display is clkout, set this to ON.
See "The Clock Section" in the manual (page 69).
http://soundcloud.com/Mefistophelees
zdogtru2
PostPosted: Sun Sep 02, 2012 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've Tried this but it still did not work. I not sure if there might be another parameter in the software that need to be changed? Thanks for your reply!
emSynth
