Inharmonique 1: Risset's Arpeggio programmed with chucK
Page 1 of 1 [6 Posts]
jkant
PostPosted: Mon May 12, 2014 9:02 am    Post subject: Inharmonique 1: Risset's Arpeggio programmed with chucK Reply with quote  Mark this post and the followings unread
Hello all,
maybe someone is interested...
http://jkant.blogspot.it/2014/05/inharmonique-1.html
best
Random Bitz
Audio files: 169
G2 patch files: 319
PostPosted: Mon May 12, 2014 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds very nice - had a glance at the chuck code .. will look better later on.
jkant
PostPosted: Tue May 13, 2014 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Jan!
There are several parameters to play with, to get interesting rhythmic and melodic fragments starting from static sinusoids.
Partials number, Delta, Amps...
Experimenting with more synths is also productive to increase the spectral matrix, even if you multiply oscillators.
ciao
Random Bitz
jbump
PostPosted: Sun May 18, 2014 4:48 pm    Post subject: re
Subject description: re
thanks for sharing! this is awesome! much fun to be had playing around with this stuff!
i am a total chuck n00b so i need some clarification on one thing: in the addsynth class, the reverb and pan are set in the loop where the individual sine oscillators are configured. aren't these global values? can they be set outside the loop? does setting these values alter the values of the sine oscillators being created?
thanks,
jason
jkant
PostPosted: Mon May 19, 2014 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jason, thanks for your feedback.
I wanted to have each partial with its own (random) pan position and reverb mix, but yes you can set them outside the loop as global or static variables for each add synth. You could even make some extra member function to manage the parameterization.
Best.
Random Bitz
aknudsen
PostPosted: Mon May 26, 2014 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I've posted a simplified, playable, version on the ChucK Demos site, feel free to check it out Smile
