  bingsatellites Mostly Ambient
Step Sequencer Problem
Page 1 of 1 [7 Posts]
EvolLove
PostPosted: Mon Sep 17, 2012 2:32 am    Post subject: Step Sequencer Problem Reply with quote  Mark this post and the followings unread
Hallo Everybody,
my G2 has a strange beaveour in the following situation:
- When a note sequencer is running it's sequence to control the pitch of the oscillators and I put a new module on the patch, without connecting any cables, the timbre of the sound previously programmed mutates. This happen only when a sequencer is controlling the pitch of the synthesis structure. Otherwise, when I play the notes on the keyboard, everything works fine.
If anybody has some idea of what's happening, I would be very grateful to him of letting me know.
Many thanks in advance.
iPassenger
G2 patch files: 78
PostPosted: Mon Sep 17, 2012 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
A new module causes the patch to recalculate.
My guess is if you have more than one OSC at the same pitch but not synced, then the reloading/recalculation of the patch is changing the relative phase of these OSC too each other. This is probably changing the sound of the sequence, if you are FM-ing, you can get a similar result but it is caused by the same thing, the relative phase of the OSC is changing the resulting timbre.
iP (Ross)
EvolLove
PostPosted: Mon Sep 17, 2012 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much for your quick and right reply but unfourtunately the issue happen also when there is just one oscillator and no FM..
iPassenger
G2 patch files: 78
PostPosted: Mon Sep 17, 2012 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you post the patch (or better still a picture of the patch, as I am at work) and we'll see if we can spot the cause.
Also are you on the Demo or a G2?
iP (Ross)
EvolLove
PostPosted: Mon Sep 17, 2012 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't happen on a specific patch and, I've just discovered, it doesn't happen all the times.
I also have another similar problem, that maby can be related and could help you understand the whole situation:
- I noticed this problem to happen only in the attached patch "Drum". After a while I start the performance the kick drum lowers it's power (something like a filtered effect). This problem doesn't happen all the times too. In the performance I have some patches receiving midi notes from Ableton Live's sequencer and everything is sincronized with the midi clock of my Allen & Heat Xone 2D.
Drum.pch2
 Filename:  Drum.pch2
 Filesize:  6.83 KB
 Downloaded:  108 Time(s)
Drum.pch2
 Filename:  Drum.pch2
 Filesize:  6.83 KB
 Downloaded:  106 Time(s)
EvolLove
PostPosted: Mon Sep 17, 2012 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyway, I'm using a G2..
Sequencer Issue.pch2
 Filename:  Sequencer Issue.pch2
 Filesize:  1.32 KB
 Downloaded:  116 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon Sep 17, 2012 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't hear the problem you describe.
The first triggered sound is sometimes a bit muted when it recalculates but i think this is due to a smoothing of the level as it fades out and fades in the patch following the calculation, to prevent loud clicks I guess.
iP (Ross)
Niio1
