  mosc Chez Mosc - Sorry, no show tonight. Next show May 23.
CGS77 - Serge VCF
Page 1 of 1 [15 Posts]
drapdap
PostPosted: Thu Dec 17, 2009 6:02 am    Post subject: CGS77 - Serge VCF
Subject description: news from 1973
Thank you sir Stone!
im just staring at the schemo... feels like an early xmas present.
http://www.cgs.synth.net/modules/cgs77_vcf.html
LetterBeacon
PostPosted: Thu Dec 17, 2009 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, very exciting!
Are there any demos available?
drapdap
PostPosted: Thu Dec 17, 2009 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
LetterBeacon wrote:
Wow, very exciting!
probably as it seems this is an the old serge classic, might be tons of records this one is featured on.
http://www.cgs.synth.net/synth/serge/vcf.html
this one, plus a buffer...
this might be a state variable filter?
beautiful stuff ...
LetterBeacon
PostPosted: Sun Dec 27, 2009 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd just like to confirm something:
To use the TL074 buffer section I would, instead of wiring as shown on the wiring diagram, connect the HP BP and LP outputs to the TL074 inputs and then the TL074 outputs to the sockets?
I don't understand the setting up instructions:
Adjustments on the vcf board are basic. Set trimmer so that the VCF's center frequency as at an appropriate pitch.
I don't understand what an appropriate pitch is!
widdly
PostPosted: Tue Dec 29, 2009 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The trimmer just adds an offset voltage to the frequency CV summer. If you set the Cutoff knob to the middle you can change what frequency the middle will be by changing the trimmer.
I don't know what real serges use but looking at moog or arp front panels show the filter cutoff centre is usually 500Hz so that would be a good place to start.
fluxmonkey
PostPosted: Fri Feb 12, 2010 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm... just noticed this on kens page for the Serge filter: "Those assembling the Euro version of this module..."
hotdamn.
www.fluxmonkey.com
jnuaury
Audio files: 9
PostPosted: Thu Feb 18, 2010 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
hotdamn.
the full quote says
"Those assembling the Euro version of this module will need to substitute two of the regular pots and the spst switches for combined units available from Mouser. P/N: 313-1600F-50k "
this is probably copy-pasted over from the VCS page
unfortunately the VCF has no switches so theres no need for theres mouser parts so theres probably not a euro board planned....
az/gde
Flickr
YouTube
andrewF
PostPosted: Thu Feb 18, 2010 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
there can be a switch -
also from the VCF page - "A DPDT switch can be added to short points F and G to 0V. Doing this will switch the filter into low-frequency mode, as per the VCFX (for CV filtering etc.). While the original Serge boards had this function, it is doubtful it was ever brought out to the panel. "
this is a worthwhile mod, CV filtering is cheeeezeeey and a rather unusual feature for a VCF.
macumbista
PostPosted: Sun Jul 25, 2010 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Built a pair of these a few months ago, just want to chime in that they are SWEEEEEET and well worth the time and expense. You can probably hear plenty of this filter in these tracks....
macumbista.net
macumbista
PostPosted: Sun Oct 03, 2010 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Is anyone else finding that the CV inputs go wild really quickly? Seems like way more than 1V/Oct. Just a little tweak off center in either positive or negative direction and the modulation is extremely wide. I'm using 25K lin pots instead of the listed 20K, but that shouldn't account for such an extreme amount of input.
macumbista.net
j.dilisio
PostPosted: Tue Oct 12, 2010 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Macumbista, what's the password to unrar that Serge Mix?
DRONEGOAT
macumbista
PostPosted: Tue Oct 12, 2010 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's in the blog post, just below the DL links... "orpheusmachine"
macumbista.net
j.dilisio
PostPosted: Tue Oct 12, 2010 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aaah! So it was right in front of me.
DRONEGOAT
xi-boy
PostPosted: Mon Oct 15, 2012 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
this filter has become one of my favorites
its specially brilliant for pinging sounds
but probably because of its wide cv range (?) its resonance loves to freak out ;-(
also the bipolar attenuator dosent close completely
i actually would prefer a uni polar attenuator
any idea how to make this filter more controllable ?
LetterBeacon
PostPosted: Fri Mar 29, 2013 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
What setting are people using for their filters? How are you guys measuring the frequency that you're setting it at?
