 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
ElasticAudio X
Page 1 of 1 [12 Posts]
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Wed Mar 25, 2009 6:08 pm    Post subject: ElasticAudio X
Subject description: deluxe polyphonic elastic audio sampler with force-pitch and formant control
dear friends,
Here's the final version of the polyphonic elastic audio synth. It offers vastly improved sound quality and precision, plus added functionality like forcing audio material to a specific pitch and controlling formants.
This design differs from the polyphonic granular synth in a fundamental way: The granular approach chops up the source audio arbitrarily into grains which clock at a specific frequency. Since these grains overlap, there is always some phase cancellation in the resulting audio which has to be alleviated by jittering the playback speed of the individual grains. Also, the grain clock bleeds into the audio considerably, and also has to be masked by jitter.
This approach works totally differently. It intelligently scans the source audio for single full wavecycles, clusters those into larger chunks of selectable size and realigns them over the time axis -all in realtime. Cool Hence, all the artefacts (or interesting effects, depending on your taste Laughing) of the granular approach don't occur and the pitch information of the source audio is preserved far more faithfully.
I also added something completely new: "forcing to pitch". When this function is engaged, the audio is indeed "forced" onto a pitch of choice. Technically speaking, the waveform clusters are hardsynced to a carrier wave, and the sharp flanks are smoothed away. When this is activated, the cluster pitch control actually changes into a formant control -so pitch, time and formants are all controllable in realtime. Cool
There's a demo mp3 attached, which demonstrates my voice saying "one two three..." (sorry Laughing), playing some notes on the keyboard and stepping through the 8 variations.
Input Section:
INPUT Source, Pad -select external input channel and pad
INPUT Monitor -listen to the input (running through the input limiter, drive and EQ)
SAMPLE Capture -samples audio (2.7 seconds)
INPUT Limiter -input dynamics
INPUT Drive -overdrive for the input, can be useful
INPUT EQ -EQ for the input, can be useful to add eg. "air" to voices
Elastic Audio Section:
SAMPLE Positio -position pointer in the sampl; also assigned to modwheel (for scrubbing the sample)
SAMPLE Speed -playback speed: from -64 (backwards) to 0 (freeze) to 64 (forwards), independent of pitch; assigned to the pitch stick (for cruising through the sample)
SPEED KBT -lets playback speed track the keyboard
SAMPLE Pitch -playback pitch of the sample, independent of speed;When pitch-forcing is activated, this parameter turns into a formant control.
PITCH KBT -sample pitch keyboard tracking
CLUSTER Size -sets the size of the wave cluster
CL-SIZE Source -this is a nifty one: when set to "cycles", the "CLUSTER Size" parameter determines the amount of single wavecycles to be clustered (when set to 0, this equals 1 wavecycle, which lets you scan through the individual waveforms of your source audio with the pitch stick. It's fun, try it.) When set to "time" however, the "CLUSTER Size" parameters determines the absolute temporal size (=time) of the cluster. This results in an uniform cluster size regardless of playback pitch.
PITCH forcing -activates the pitch forcing function
WAVE smoothing -amount of smoothing applied to the pitch-forced waveforms
FORCED PITCH Coarse, Fine -destination pitch
POSITION Jitter -jitters the sample position
PITCH Jitter -jitters the sample playback pitch
CL-SIZE Jitter -jitters the cluster size ("time" mode will logically render this ineffective)
F-PITCH Jitter -jitters the destination pitch of the pitch-forcing process
The rest is vanilla stuff -filter, amp envelope, chorus, stereo delay, reverb, blablabla.
As usual, this patch uses a DSP per voice, so 3 voices for unexpanded and 7 for expanded G2s.
Also, this patch uses 3 interslot buses!
yupp, that's it. Enjoy. Smile
best,
tim
The demo mp3 demonstrating the 8 variations:
1 - straightforward sample playback, freeze with the pitch stick
2 - freeze with some jitter, cruising about with the pitch stick
3 - force-pitch tonal pad
4 - glitchy warble (big clusters with copious pitch jitter)
5 - slowly scanning single wavecycles
6 - fixed force-pitch with keyboard-tracking formant control
7 - warbling cloud
8 - force-pitch pad with extreme formants
OneTwoThree.mp3
audio demo of the ElasticAudioX patch; sampled voice saying "one two three...", noodling around and stepping through the 8 variations.
 Filename:  OneTwoThree.mp3
 Filesize:  2.31 MB
 Downloaded:  1176 Time(s)
ElasticAudioX_TK.pch2
Final version of the polyphonic elastic audio synthesizer. Vastly improved algorithm, better sound quality, more functionality.
 Filename:  ElasticAudioX_TK.pch2
 Filesize:  8.47 KB
 Downloaded:  1009 Time(s)
beer
seraph
Editor
Editor
Audio files: 31
PostPosted: Thu Mar 26, 2009 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
unexplainable but awesome Exclamation
Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master
iPassenger
G2 patch files: 78
PostPosted: Thu Mar 26, 2009 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yet again its amazing tim, nice work.. Haven't loaded it up yet (at work) but the demo sounds brill.
iP (Ross)
drapdap
PostPosted: Thu Mar 26, 2009 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
the demo is so funny, i listened three times by now...
Tim, we're so glad you are. Smile
biggest possible thank you!
robert
mtvic
PostPosted: Thu Mar 26, 2009 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like Konky the Robot from Pee Wees' Playhouse.
Very useful fun pch
PostPosted: Thu Mar 26, 2009 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
No wonder Clavia have discontinued the G2! Shocked This is f**king tapped (probably quite literally too eh?) Tim!!
You are a genius mate Very Happy Very Happy
Oh yes Clavia- they have probably realised from your patches alone why it was so silly to leave out sampling on the G2, and why sampling will now appear on the G3........Hooray!! Well just a thought! Cool
And thanks for uploading that mp3 too! Exclamation
ACHTUNG!
W.T.
G2 patch files: 11
PostPosted: Sun Mar 29, 2009 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
this is going t be a great Sunday afternoon !
wave
mother misty
G2 patch files: 130
PostPosted: Sun Mar 29, 2009 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
wave
+1 Wink
Fantastic patch tim! thank you so much for sharing cheers thumb up too much coffee love banana
misty.
http://www.myspace.com/mariodemeyer
BobTheDog
PostPosted: Sun Mar 29, 2009 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I just think its amazing you can do this on a G2!
Bloody Clever stuff.
gomidas
G2 patch files: 6
PostPosted: Sun Mar 29, 2009 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
wow!
Another 'Magic' patch from you Tim!
To boldly go where no man has gone before Shocked
Thanks for sharing!
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Sat Apr 11, 2009 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice this one is pretty easy to control!! Very Nice Patching!
tnx i will try to use this for some nice vocals Very Happy
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Apr 17, 2009 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
WTF! OMG! Amazing!
The mp3 demo is simply stunning.
Albert
Niio1
