Using non-insulated jacks...
Page 1 of 1 [4 Posts]
Marcinkevicius
PostPosted: Tue Nov 27, 2012 8:12 am    Post subject: Using non-insulated jacks... Reply with quote  Mark this post and the followings unread
First of all I would like to say HI! to everyone on this forum. I'm a new user here but hope to have a good and educational time.
I'm currently building Yusynth modules, have VCO, ADSR, Moog VCF and few others perfectly working. Now its time to place them into the safe and cozy chassis.
So the question is: has anyone tried using non-insulated 1/4' jacks? Has anyone encountered problems caused by ground loops through chassis? Or maybe these issues do not exist in modular systems Very Happy I'm kinda new to this...
Thanks for answers in advance. Cheers!
Audio files: 116
G2 patch files: 317
PostPosted: Tue Nov 27, 2012 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Marcinkevicius
do 1/8" jacks count too?
It is all not too critical, but strictly speaking non-insulated connectors would cause ground loops indeed when the cable shield is connected at both ends.
When you do not want this, but you do want shielded cables, you probably want to make your own cables where at one end the shield is not connected.
Otoh, shielding for patch cables is not really that important with the signal levels and impedances being used. So ... you could just as well use unshielded cables for patching, which are then pretty easy to make.
That last thing is what i did for my formant.
But then again, shielded cables did not cause any trouble for me either .. which is to be expected with the high signal levels / low impedance .. and those can be be bought instead of made.
Sooo .. how purist you want to be or not to be is the question Wink
Marcinkevicius
PostPosted: Thu Nov 29, 2012 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha ha, good one. But seriously i still prefer 1/4'' for being more robust and fitting to my hand better.
I was thinking the same about shielded patch cables. Shielding patch cables really don't look necessary since the signal amplitudes are relatively high. Well except those going from modular to mixer/sound card/whatever. These I'm gonna make myself well shielded.
Thanks for sharing your thoughts! Made me to take my decisions much easier.
Cheers!
Audio files: 116
G2 patch files: 317
PostPosted: Thu Nov 29, 2012 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree with you completely, the thing just happened to have 1/8" ... Confused
