Program Control Of
sontag
PostPosted: Mon Dec 03, 2012 6:48 am    Post subject: Program Control Of Reply with quote  Mark this post and the followings unread
I don't know the OS of the unit, I don't know how to see it. The computer OS is win 7. I use cubase 5.
The problem is: when I change a parameter of part D, also change this parameter in part B an C.In the function SHIFT+PROGRAM CONTROL if I select "C.of" the problem solve. The function I suppose is Control Change, that now I can control each part A, B, C, D independently. But the problem now is when I want to record a control change to make an automation in the Daw affect 3 or more parts. Is the unit broke or it is normal?
Niio1
