Posted: Thu Mar 14, 2013 12:55 am Post subject:
Binary Game Sequencer Subject description: a divider based CV generator... |
hi all,
this is what i finished last night. i am still missing the front panel, so the LEDs are not mounted yet...
it is a new kind of an unipolar sequencer, based on a binary counter/divider (4024), instead of a decade counter/divider (4017).
the concept: each divisions output is routed to an attenuator. the divisions attenuated voltages are then summed.
the realization: each divisions output controlls a CMOS switch. these switches have sockets on it's inputs, normalled to +V. so for each division you could use an external voltage also. this voltage is then going to a simple passive attenuator, and is then routed to one or none of the two CV mixers (on/off/on toggle switch).
additionally each division is converted to a trigger and available at a divider output socket.
a step and reset control makes it complete.
taking a look at the pictures below you see for each division from top to bottom: external voltage input, attenuator, routing switch, LED indicator, division trigger output. bottom row is for I/O (clock, reset, CV outputs A & B).
the nice thing is that you create two CV sequences that are related to each other.
schematics, demo and better pictures will follow as soon as i got the front panel... i just had to share.
[edit: photos replaced]
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) Last edited by fonik on Thu Mar 14, 2013 11:10 pm; edited 2 times in total |
The Bad Producer
Joined: Mar 08, 2009 Posts: 235 Location: The Manhole
Posted: Thu Mar 14, 2013 3:56 am Post subject:
| The Bad Producer wrote: | | Hey Matthias, that's really cool - so if I get this right, you can send each steps voltage to be summed at either A or B or off at the flick of a switch? |
correct, however, "stage" might be describe it better than "step".
BTW today i learned that the blacet binary zone follows a similiar concept, but is bi-polar, without the switches, no external voltages inputs, and w/o the /128 division (stage #7). _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
The Bad Producer
Posted: Thu Mar 14, 2013 6:39 am Post subject:
I was obviously somewhere else this morning! I get it better now, helped by the panels pic on Muff's, i think I was confused with the binary counting, I went somewhere else, actually seems better now I properly get it  _________________ http://loudestwarning.tumblr.com/
http://soundcloud.com/thebadproducer |
Posted: Fri Mar 15, 2013 3:18 pm Post subject:
so here is a 1st sample i did. no big deal, just the Binary game Sequencer, the doepfer quantizer, two thomas henry VCOs (555 and 4046) and my LPG. 1min of patching and it sounds like this:
fonitronik at
Posted: Fri Mar 15, 2013 6:41 pm Post subject:
| Nice! |
tony void
Posted: Sat Mar 16, 2013 9:37 pm Post subject:
| Listened to this earlier today on my sound cloud subscriptions. Very pleasing to the ears. Had to check this sub forum to what it was all about. Cool idea! |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Sun Mar 17, 2013 3:12 am Post subject:
Very nice Mathias!  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Audio files: 51
Posted: Fri Mar 22, 2013 1:05 pm Post subject:
Hey Matthias,
I think you'll find that in english it's spelt - genius !  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Joined: Apr 03, 2004 Posts: 19598 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Mar 22, 2013 1:57 pm Post subject:
| Uncle Krunkus wrote: |
Hey Matthias,
I think you'll find that in english it's spelt - genius !  |
I thought :breakfast:  _________________ Jan |
Posted: Sun Mar 24, 2013 4:04 am Post subject:
last night i made a quick video. no time, no light, bad camera, bad vid quality... anyways, it shows the basic functionality and concept, i think.
quick and dirty demo of my new binary sequencer from fonitronik on Vimeo.
(each CV channel to a X4046 VCO. 1st division trigger out to LPG for 1st VCO, 2nd division out to 12db SVF - in the beginning only channel A, later on channel B fades in. switch set to left routes the CV to channel A, to the right channel B, center position OFF) _________________
fonitronik at
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
LektroiD
Joined: Aug 23, 2008 Posts: 960 Location: Scottish Borders
Posted: Wed Apr 17, 2013 8:01 am Post subject:
I hope these will be available as kits in the near future... _________________ My tunes available here
(check out the new Electro-Funk LP) |
Joined: Jan 07, 2009 Posts: 588 Location: Scottish Borders
Audio files: 69
Posted: Mon Apr 29, 2013 10:42 am Post subject:
Hi Matthias
i'd be interested in pcb's if you are doing a run.
Dave. _________________ www.myspace.com/skrogproductions |
Posted: Mon Apr 29, 2013 12:24 pm Post subject:
i will do a run, if there is enough interest.
i already did a re-design of the circuit board to match the eurorack front panel PCB. they could be mounted piggyback to avoid any manual wiring (however, i know that there are not that much eurorack lovers here, no?).
anyways, i will have to finish two other prototypes first (TH ADSR, and the new fonitronik triple vactrol resonator).
fonitronik at
mcop
Posted: Mon Apr 29, 2013 10:03 pm Post subject:
| I'd be interested in a set of boards if you do a run. Particularly interested in it's ability to take external inputs, makes for some very interesting possibilities. |
