AC DC VCA Quick question
Page 1 of 1 [6 Posts]
joshco
PostPosted: Sun Oct 25, 2009 4:05 am    Post subject: AC DC VCA Quick question Reply with quote  Mark this post and the followings unread
Hello,
Currently I´m building some VCA´s, theres a DC and a AC Version.
What does this mean in general, are there any differences in sound or in amplification?
Thanks
best regards
yusynth
PostPosted: Sun Oct 25, 2009 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The AC version is solely dedicated to process audio signals that's why there are capacitors in series with the INPUTS. These capacitors are there to filter out any DC component.
The DC version is more versatile because it can be used for processing either CVs or audio signals.
Yves
joshco
PostPosted: Sun Oct 25, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Allright, the caps remove the dc signal in the audio material, whereas the DC version is able to amplify DC signals too.
Thank you!
robboten
PostPosted: Mon Feb 25, 2013 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
In the schematic for the simple VCA module there are two stars at the LED and the circuit around it. Does that mean that the LED only works with the AC version? That could explain why I get no light... And if so, is it possible to have light with the DC version as well?
yusynth
PostPosted: Tue Feb 26, 2013 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have installed all these optional components and use it in DC mode then the LED can bright but only for a negative input voltage. The LED circuit was designed for AC only as indicated.
Yves
robboten
PostPosted: Tue Feb 26, 2013 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I see. Thank you for your reply!
And also a big <3 for all your work on the modules you have published! I just love everything about them! The clearness of the pictures, the easy to follow schematics, the pcb-layouts and the functions. For me as a noob on the field this has helped me understand so much! Build my fourth module today (Noise, VCA, ADSR, S&H) and is so happy about it all! Next up is a mixer or the Steiner VCF. Probably ending up with all of them sooner or later... it's so much fun! So thank you again so much!
mps board
