THAT corp IC layout
Page 1 of 1 [6 Posts]
tony void
PostPosted: Wed Dec 12, 2012 10:14 am    Post subject: THAT corp IC layout Reply with quote  Mark this post and the followings unread
Question Why don't I see more layouts using these ICs.
Seems like it would make $ense for things like Moog filters and "tau pipe" phase shilfters using these. SSM2210s, lm394s, are hard to find and cost too much. Maybe I'm missing something I'm not exactly the most tech savvy person
krisp14u
PostPosted: Fri Dec 14, 2012 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Oakley use the THAC Corp matched pairs in quite a few projects
VCO
Ring Mod
Journeyman and Superladder VCF’s
Classic VCA
Paul Darlow
www.krisp1.com
emdot_ambient
PostPosted: Thu Dec 20, 2012 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Many of L-1's DIY projects use them as well, such as his High Quality Quad VCA/Mixer project:
http://www.electro-music.com/forum/topic-51088.html
LFLab
PostPosted: Thu Dec 20, 2012 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Can highly recommend this one:
http://www.acxsynth.com/VCA/vca.htm
Quite a simple build with 2181
tony void
PostPosted: Sat Dec 22, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you and for the links, freinds. I plan to do some pcb layouts using these chips for some of the projects out where it would just make economical sense to do so. It's been more than 20 years since I layedout and etched a pcb. So we'll how it goes.
LFLab
PostPosted: Sat Dec 22, 2012 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, if you do start your own layouts, I can highly recommend Eagle to do them. There's a free version but also a hobbyist license for 60 euros. Bit of a learning curve but not too much so (IMHO).
