j.dilisio
Posted: Sat Oct 20, 2012 3:44 pm Post subject:
Mr. Haible's OB-Xa sound mod for OB-8 Subject description: anyone else try this? Not working for me. |
I just tried the OB-8 mod as described here..
http://machines.hyperreal.org/manufacturers/Oberheim/OB-8/mods/OB-8.mod.txt
.. but rather than opening up the sound what I got was muted low frequencies.
It looks so simple. A resistor and a capacitor in series- in parallel to another resistor.. and this is supposed to offset the 22Hz highpass.
I don't really understand the electronics enough to know if he might have made a mistake listing a value or not.
Has anyone else had good results from this mod?
Thanks,
J _________________ DRONEGOAT |
j.dilisio
Posted: Sun Dec 09, 2012 6:25 pm Post subject:
I never did get this to work but I did successfully manage Jurgen's multimode filter mod..
http://www.jhaible.de/hjob8mod.html
.. and it rocks! I would highly recommend this to any OB-8 owners.
The high pass filter really opens up a new sonic spectrum for this instrument. _________________ DRONEGOAT |
radek tymecki
Posted: Mon Dec 10, 2012 12:19 pm Post subject:
i've managed to do audio mod and there was a diffrence to me! i did it on one board and compared 2 voiceboards. the one with mod had low freq boost
i always wanted to make a multimode modification but i was afraid I could not handle i was speaking bout it with Juergen but suddenly he passed away...
do You have photos how did You performed multimode filter mod? |
j.dilisio
radek tymecki
Posted: Tue Dec 11, 2012 1:36 pm Post subject:
i'll be back in poland in one week i think. now i'm in NL. then i'll take the photos
can u post some audio examples? |
j.dilisio
j.dilisio
Posted: Thu Dec 13, 2012 10:52 am Post subject:
Here's a demo of the four filter modes. I just calibrated the resonance so that it's a little higher than specified. You'll hear this on the 2-pole and highpass modes.
2-pole > 4-pole > 6dB > highpass
http://jdilisio.com/ob8/OB-8Filters.mp3 _________________ DRONEGOAT |
radek tymecki
Posted: Sat Dec 15, 2012 2:19 pm Post subject:
oh man! this shit rocks!
tomorrow i'll try to look after spare 4052 and try to mod ob8!
anyway... i'll keep ya informed in progress! |
j.dilisio
Posted: Sat Dec 15, 2012 2:43 pm Post subject:
Here are a few tips..
-You don't have to cut the traces to the cx21 capacitors. Just cut or desolder the leg leaving enough of the lead so that you can solder a connection to it later.
-It is much easier to make the connection to pin 14 of ux07 before you mount the chip and solder pins 8 and 16.
Good luck. _________________ DRONEGOAT |
radek tymecki
Posted: Sat Dec 22, 2012 10:38 am Post subject:
i've noticed that you dont have to solder a wire to pin 14. you can also solder it info hole after desoldered cap. anyway i'm in a half way. one of 4052's got damaged and i have to buy new one. then i'll be able to finish it
anyway. do you know how to calibrate arpeggiator? mine acts weird. when i press a note - C for example, ob8 arpeggiates it and later changes transposition etc |
radek tymecki
Posted: Sat Dec 22, 2012 12:36 pm Post subject:
| i just finished this mod! KICKS ASS! |
j.dilisio
Posted: Sun Dec 23, 2012 1:36 pm Post subject:
Cheers! You should check out the arpeggiator section in the manual. It's pretty complex. You can program up to 5 transpositions.
Post a photo of your bass boost mod when you get a chance. _________________ DRONEGOAT |
radek tymecki
Posted: Sun Dec 23, 2012 1:59 pm Post subject:
tomorrow i'll make hi res pictures. these were made using my cell. anyway as far as i can remember i changed 4 resistors and made a network... another resistor and 47+10 nf cap.
j.dilisio
Posted: Wed Jan 02, 2013 6:10 pm Post subject:
I just realized I was using 120ohm resistors instead of 120k  _________________ DRONEGOAT |
radek tymecki
Posted: Thu Jan 03, 2013 8:10 am Post subject:
haha good eye man!
is it working for you now? |
radek tymecki
Posted: Thu Jan 03, 2013 1:31 pm Post subject:
| ps. do you want to build polymod? |
j.dilisio
Posted: Sat Jan 05, 2013 10:35 pm Post subject:
It's working now! The difference is more subtle than I expected but definitely noticeable.
I'm interested in the polymod but I'd like to hear a sample of how it sounds. I get the feeling I wouldn't have much use for it. _________________ DRONEGOAT |
