sonicwarrior
Joined: Dec 22, 2005 Posts: 189 Location: Cologne, Germany
Posted: Sun Feb 10, 2013 3:41 pm Post subject:
Closed |
Closed Last edited by sonicwarrior on Wed May 01, 2013 10:23 am; edited 7 times in total |
sonicwarrior
Posted: Mon Feb 11, 2013 6:24 am Post subject:
Re: FS (EU): PCB's and front panels Subject description: MFOS ADSR, MFOS AR, CGSRR, CGS DUSG, Dual DBX VCA, Melcor 1731 |
| sonicwarrior wrote: | | 4 x MFOS ADSR kit + Bridechamber front |
Btw.: If anyone is interested in the front panels only I'm willing to sell them separately but I won't sell the PCB kits separately.
The breadboard stuff is really simple (LED driver is a transistor and some resistors, the inverter is mainly a single op amp and some resistors). And instead of the LED you can mount a speed switch there (the hole is big enough for standard switches).
I build one of these ADSRs and found the inverted output pretty useful but I'm more into Buchla/Serge Slew Limiter multitool modules nowadays than standard ADSRs + I already have 3 ADRSs in my 5U system. |
roglok
Posted: Tue Feb 12, 2013 10:42 am Post subject:
| someone grab the MFOS Dual AR - it's a great module! |
sonicwarrior
Posted: Tue Feb 12, 2013 2:12 pm Post subject:
Thanks. The ADSRs are great, too, but I already have too many.
It seems like no one is building MOTM modules anymore.  |
Posted: Tue Feb 12, 2013 3:22 pm Post subject:
| I'm doing MOTM format, but then again I don't need any of these modules, I'm really in need of sequencers and other sources of control voltage.... |
sonicwarrior
Posted: Sat Feb 16, 2013 5:49 am Post subject:
| Added a dual mic pre set and two Lundahl LL1521. |
Alfredo
Posted: Sat Feb 16, 2013 7:13 am Post subject:
MFOS AR |
Hello, I will take the MFOS AR.
Thanks. |
sonicwarrior
Posted: Sat Feb 16, 2013 7:26 am Post subject:
Re: MFOS AR |
| Then please send an email to the address I PMed you. |
Alfredo
Posted: Mon Feb 18, 2013 4:57 am Post subject:
I PMed you |
| Hello, I already PMed you back. |
sonicwarrior
Posted: Wed Feb 20, 2013 12:56 pm Post subject:
Re: I PMed you |
Yes, but I wanted an email not a PM.
Anyway the MFOS AR has gone in the meantime. |
Alfredo
Posted: Wed Feb 20, 2013 4:22 pm Post subject:
Not good man |
I sent you an email too same day, that´s no good man  |
sonicwarrior
Posted: Thu Feb 21, 2013 2:21 pm Post subject:
Re: Not good man |
| I sent you my email address on the 12th and got your email at the 17th in the meantime (5 days!) someone else emailed me. Prior to your email I only got PMs from you and I don't do business via PMs. |
Alfredo
Joined: Apr 03, 2004 Posts: 19582 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Thu Feb 21, 2013 5:07 pm Post subject:
@sonicwarrior ... I don't see an email only response request in your starting post here, maybe it would be a good idea to add it - I guess you said so in a later PM, still it might help to get less misunderstanding?
@Alfredo .. I'm sorry to see you getting so disappointed about the failed deal, and I of course do not know the details of the affair, but from what is visible here in the thread .. could it be that you are overreacting a bit? _________________ Jan |
Alfredo
Posted: Fri Feb 22, 2013 8:15 am Post subject:
Thanks Blue Angel |
Thanks Blue Angel for your attention, no problem I preffer to finish.
Sorry sonicwarrior. |
sonicwarrior
Posted: Fri Feb 22, 2013 2:17 pm Post subject:
| Blue Hell wrote: | | I don't see an email only response request in your starting post here, maybe it would be a good idea to add it - I guess you said so in a later PM, still it might help to get less misunderstanding? |
For me it's normal to not send sensitive informations via PM. I never had a problem with anyone writing an email until now with Alfredo and I sold much stuff over the years. I clearly said in my PM from the 12th that he should send me an email ([shipping costs to Spain] 'If you are still interested please write an email to ...'). On the 16th someone else contacted me and was able to respond directly per email so he got the MFOS AR PCB. Alfredo finally was able to write an email on the 17th but that was too late then. I only reserve stuff when I got a notification via email that payment is on the way. I do that because I got lots of PMs from people who have not been serious or changed their mind but everytime I got an email I got a deal. I guess people take emails more serious than PMs. |
Audio files: 116
G2 patch files: 317
Posted: Fri Feb 22, 2013 4:07 pm Post subject:
| sonicwarrior wrote: | | For me it's normal to not send sensitive informations via PM. |
I understand and would do the same. Not that such matters, as it is up to you how to handle selling your things.
And just to be sure, I am not blaming anyone, just tried some suggestions. Anyway, thank you for your explanation. _________________ Jan |
sonicwarrior
Posted: Fri Mar 01, 2013 12:11 pm Post subject:
Re: FS (EU): PCB's and front panels Subject description: MFOS ADSR, MFOS AR, Dual DBX VCA, Melcor 1731, Dual MicPre, Lundahl |
| sonicwarrior wrote: | 4 x MFOS ADSR kit + Bridechamber front, 50 € each
This is the old Bridechamber front panel in MOTM format with LED + inverted out |
I'm willing to sell the Bridechamber fronts separately for 25 € each if anyone is interested. |
modulardoom
Posted: Wed Mar 13, 2013 6:31 pm Post subject:
MFOS ADSR |
I am interested in one MFOS ADSR Kit + front panel
send me a PM if they are available.
thanks a lot |
