FS: Mega Percussive Synth MOTM format
peng
PostPosted: Thu Jul 25, 2013 12:30 pm    Post subject: FS: Mega Percussive Synth MOTM format Reply with quote  Mark this post and the followings unread
MOTM format MPS module.
I have two for sale.
was $600 each
$500 each or $900 for the pair
+ shipping
With the power connector attached these are slightly less than 2" depth behind the panel. Perfect for a slim cab drum synth.
I have been playing these (four actually) with piezo style drum trigger pads.
Great dynamic response to playing.
Super addictive.
Additional details:
These are two remaining from a build order of six. The pcbs were stuffed by another person (fellow Wiggler).
These include the Noise filter frequency CV input. Circuit has been adjusted so negative voltages will do no harm, IOW - it's bullet proof.
Noise CV input is a great addition to the module. You can use it to sorta mute the noise section of the module (LP with Frequency full CCW).
I also like feeding it an LFO and imprinting rhythms over the hit.
pots are alpha 16mm
jacks are Switchcraft
switches are NKK
 Filesize:  227.34 KB
 Viewed:  33 Time(s)
 Filesize:  194.81 KB
 Viewed:  35 Time(s)
