protecting the baby
Page 1 of 1 [5 Posts]
spippoli
PostPosted: Sun Nov 23, 2008 3:47 am    Post subject:  protecting the baby
Subject description: input/output protection
Hi all,
I'm planning the construction of a full patched soundlab plus, and as I've been taught I've always practiced safe sex... so I'm considering protecting inputs and outputs
For logic inputs I'll follow what master Ray explained here:
while if I understood correctly cv inputs needs not to be protected due to their high impedance, right?
Is there a way to protect outputs? I mean something that saves my soundlab if I accidentally connect outputs to outputs.
Another thing I'd like is to sync the S&H to an external clock. Would a swithced jack in series between lf444:1 and c1 do?
The schematics of the S&H is this one http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH_PLUS/pdf/microsampleandhold_schem.pdf
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Nov 23, 2008 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi spippoli Shocked
welcome to electro-music.com Exclamation
what a great screen name (from an Italian point of view) well done
richardc64
Audio files: 26
PostPosted: Sun Nov 23, 2008 11:42 am    Post subject: Re: protecting the baby
As long as outputs have a series resistor, like R21 at the bottom of the schematic, no damage should result from connecting outputs together. In fact, doing so can produce a useful result when applied to a module's input, as the two (or more,) signals will be averaged, which will have a different effect than connecting each to separate inputs of a module, where signals are (typically) summed.
"I am endeavoring, ma'am, to create a mnemonic memory circuit... using stone
knives and bearskins." -- Spock to Edith Keeler
spippoli
PostPosted: Tue Nov 25, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Seraph, and thanks richard for the reply!
Any idea for the S&H mod?
richardc64
Audio files: 26
PostPosted: Tue Nov 25, 2008 4:22 am    Post subject: Re: protecting the baby
Off hand, I'd say yes, but it's not clear to me how large a pulse is needed to trigger Q1. Try it, but put a resistor 470ohm-1K between U1A ouput and the jack switch terminal.
