  bingsatellites Mostly Ambient
Pitch bend control
Page 1 of 1 [4 Posts]
King Rat
G2 patch files: 13
PostPosted: Thu Sep 01, 2005 2:16 am    Post subject: Pitch bend control Reply with quote  Mark this post and the followings unread
Just a very simple thing, but incredibly useful for expressive playing. Just had to dig it out again for a lead patch, so thought I'd post it up...
Ever get annoyed by the way pitch bend "follows you back down" when you release the pitch stick (e.g. in lead patches with long release times) when you really want it to hang on the note while you hit another one.
Just a constant mod (with value morphed by the pitch stick to the extent desired) going through a T&H mod (controlled by kyb gate) hooked up to the pitch input of an osc (obviously, turn off the built-in pitch bend, although leaving it on can produce some funny results).
Pitch stick bypass.pch2
Bldg block for bypassing the pitch stick once a note is released to prevent it from sinking back to it's original pitch.
 Filename:  Pitch stick bypass.pch2
 Filesize:  1.37 KB
 Downloaded:  562 Time(s)
Project
PostPosted: Mon Oct 10, 2005 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great! this is something that I was really searching for. I'm wondering if is possible to have a version where all the notes sustained with the sustain pedal are not affected by the pitch bend, only the notes sutained with the keyboard are affected by the bend
thanks in advance
Project
Rome, Italy
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Mon Oct 10, 2005 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
AFAIK there is no way a patch can distinguish between notes held by the pedal and those held by your hand. Sad
deknow
PostPosted: Mon Oct 10, 2005 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i don't do this kind of thing, but it occurs to me that one could detect the sustain pedal being down, and retransmit midi data to a differant slot on a differant channel. not perhaps what you were looking for, but a workaround.
deknow
emSynth
