 Forum index » Instruments and Equipment » Cubase
MIDI Reassign in Cubase Sx
Page 1 of 1 [5 Posts]
Lukeys
PostPosted: Sun Nov 20, 2005 4:52 pm    Post subject: MIDI Reassign in Cubase Sx
Subject description: need a midi lug in to do this job
Hi allez!
I need a midi plug in to recreate the "reassinging voice logic" used in Oberheim 4 e 8 voice.
I mean would like to recreate a situation like this:
1)I press a key and the note is sent to the first midi ch #1 of the virtual instrument.
2) If now I press a key while the older one is still kept (note off for the first note not sent) the second note will now be sent to midi ch #2
3)If a further key is pressed while note on ch#2 is still playng it will be sent on ch #3 and so on
anybody know how to get a midi plug in that do this ?!
THANK YOU
Audio files: 107
PostPosted: Sat Dec 03, 2005 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome to the electro-music.com forum.
I can't answer your question, but I hope by bumping this someone will notice and give you an answer...
Lukeys
PostPosted: Sun Dec 04, 2005 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank YOU so much!
And by the way,congratulation for this wonderful site!
Well,at this point I wonder if there is a vsti that already has this feature.
maybe a virtual copy of those oberheim machines.
I think Arturia should make one!
L
Audio files: 107
PostPosted: Sun Dec 04, 2005 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not a VST user but I have tried a lot of programs that process MIDI on the computer. I think you could go with MAX/MSP or PD. Also, another option which is extremely good is KeyKit, by our own member Tim Thompson. See: http://nosuch.com/keykit/index.html
The Why Project
PostPosted: Sun Dec 04, 2005 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a look here:
SplitPoly from Frank's midi plugins can certainly do this...
http://www.midi-plugins.de/mplug-splpol.html
Or maybe NicFit's ndc_ch_drive:
http://asseca-pt.net/nicfit/ndc_ch_drive.html
Or maybe the MFX Note Rotator:
http://www.tencrazy.com/gadgets/mfx/
Or maybe Paralogos Orchid:
http://www.paralogos.com/music/
Good luck!
Kind regards,
The Why Project
