patch active ?
Page 1 of 1 [4 Posts]
deknow
PostPosted: Fri Oct 14, 2005 10:06 am    Post subject: patch active ? Reply with quote  Mark this post and the followings unread
ok, i'm sure there is a simple way to do this, and that someone has already done this.
i want to use the logic pulse from the "patch active" output to ramp up the volume of the patch (to avoid clicks when changing programs). is there a cheap way to do this? my method uses a flipflop, highpass filter to avoid a click, and a level mod. is there a better way?
deknow
Audio files: 130
PostPosted: Fri Oct 14, 2005 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if it is better, but you could use a glide module instead of the HPF.
Wan
G2 patch files: 46
PostPosted: Sat Oct 15, 2005 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you could use an envelope generator patched over the total output and triggered by the patch active gate. And then the attack time sets the ramp.
Question
Grtz Wan
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Oct 15, 2005 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
or reset an unlooped sequencer ... running on midi clock
nice for slow evolving effects with glide of course and lfos galore (amplitude modulated by the sequencer) ...
/Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 )
