  bingsatellites Mostly Ambient
UK maplin replacement for mpf102?
Page 1 of 1 [7 Posts]
thapoke
PostPosted: Wed Jan 04, 2006 9:19 am    Post subject: UK maplin replacement for mpf102? Reply with quote  Mark this post and the followings unread
Hi
Does anyone know a substitute for the mpf102 that is available at maplins?
thanks
dnny
PostPosted: Wed Jan 04, 2006 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi poke
try 2N3819
see the maplin page for more details.
but be careful the pins are not oriented in the same way in MPF102 and 2N3819 -
MPF102
pin 1 = drain
pin 2 = source
pin 3 = gate
2N3819
pin 1 = source
pin 2 = gate
pin 3 = drain
Macaba
PostPosted: Wed Jan 04, 2006 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
HEADS UP:
As you live in the UK, don't forget to make
www.rapidelectronics.co.uk
Your main source of electronics, as they are way cheaper than maplin and more range too.
This page shows the 2N5457 which is a very good replacement for the MPF102
http://www.rapidelectronics.co.uk/rkmain.asp?PAGEID=80010&CTL_CAT_CODE=&STK_PROD_CODE=M29822&XPAGENO=1
thapoke
PostPosted: Wed Jan 04, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
ta very much!
bugbrand
PostPosted: Wed Jan 04, 2006 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
GOOD CALL! Maplin generally suck ass, Rapid generally BEST!
(always good next day delivery (free over £30 order) and so much cheaper than Maplin)
http://www.bugbrand.co.uk
Macaba
PostPosted: Wed Jan 04, 2006 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget if you order at the weekend delivery is free regardless of order size!
bugbrand
PostPosted: Thu Jan 05, 2006 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought that offer only run for a month or so last year..?.. Is it def. still going on? If so:::: ACE!
Niio1
