Unison module
Page 1 of 1 [23 Posts]
dorremifasol
G2 patch files: 49
PostPosted: Fri Dec 29, 2006 3:27 am    Post subject: Unison module
Subject description: probably in the fx area
I haven't seen this requested before, so here it is.
The thing is that I haven't found yet a good way to make true unison patches (without using more than one slot).
A Unison module in the FX area where you could tell how the number of notes to use, the stereo spread amount and the detune amount would be really cool.
The module would need a pair of inputs (for the stereo mix) or just one for a mono input, and a pair of outputs for the final mix.
Well I'm talking about a true Unison feature using true polyphony, not an effect Smile
Albert
PostPosted: Fri Dec 29, 2006 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
By disabling the KBT control, and using a "monokeyboard" module, you can achieve nice unison effects. In this example, the amount of detune is set by the Voice No., adjust it by turning the Pitch Modulation of OscB1. Also, the Random module B1, is in "Poly" mode, so each voice has a slight variation to the filter and pan effects.
On the keyboard or in the editor, change the voice count to see how the variation sounds. I can easily get 32 voices simultaneously on an expanded G2, though this example defaults to 4.
It's easy to forget in the G2, all voices and all slots are always making sound. It's up to envelopes and such to STOP sound, rather than the style of most synths that dynamically allocate voices to unused resources.
unison_example.pch2
Patch to illustrate voices of one patch/slot in unison.
 Filename:  unison_example.pch2
 Filesize:  1.32 KB
 Downloaded:  1559 Time(s)
dorremifasol
G2 patch files: 49
PostPosted: Fri Dec 29, 2006 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Thank you very much for the example, it's really cool to have 32 saws screaming at once, sounds great.
Still, it would be nice having an unison module because this method doesn't allow to have polyphonic instruments. I'm thinking about an unison pad Smile
Albert
PostPosted: Fri Dec 29, 2006 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could assign the "KB" control on the envelope & oscillators to MIDI, then enable/disable at will. Not that I'm discouraging your request, just pointing the work arounds out.
dorremifasol
G2 patch files: 49
PostPosted: Sat Dec 30, 2006 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I don't get it, how can I make a polyphonic instrument of 4 notes * 4 voices for example (that is, 16 voices in total)?. The method you described works very well for monophonic though. Very Happy
Albert
PostPosted: Fri Jan 05, 2007 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
This is something that could be done fairly easily if there were a macro feature in the G2. You would encapsulate your patch in a macro, and then create, say 5 instances with varied frequencies.
Too bad...
/stefan
cappy2112
PostPosted: Fri Jan 05, 2007 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
So can we expect a new "Jump" patch in 2007? Smile
jamos
G2 patch files: 39
PostPosted: Fri Jan 05, 2007 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Isn't a polyphonic unison patch a contradiction.. a logical impossibility?
The G2 has lots of ways to stack oscillators and voices.. check the patch archives for details.
As for the macro-wishing from a few posts back: there's no need for macros to do this, just copy and paste all the voice modules and duplicate as necessary.
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Fri Jan 05, 2007 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is another one.
dorremifasol
G2 patch files: 49
PostPosted: Sat Jan 06, 2007 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That patch sounds great Ian, thanks Smile
Albert
PostPosted: Sat Jan 06, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
On my Yamaha An1X you can turn on "unison", which means that one keypress will trigger 5 (i think) voices with slight frequency variations, creating a "fat" sound. Two keys will trigger 10 voices.
It is possible to copy/paste, but what if you find you want to change one module or change a filter setting? For 5 voice unison you'll have do every little thing 5 times. Macros would make this a less painful chore.
Stefan
Audio files: 231
G2 patch files: 319
PostPosted: Sat Jan 06, 2007 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
..., but what if you find you want to change one module or change a filter setting?
Morphs, MIDI CC's and use of control inputs connected to a constant, use of module colors helps as well.
I know you knew that of course Very Happy And not at all meant to invalidate the macro idea (as I certainly would appreciate to have 'm), but macro's would require 'some' planning and housekeeping as well.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue May 20, 2008 4:57 am    Post subject:   Reply with quote  Mark this post and the followings unread
That real unison sound can't be compared with any of those patches made above.
G2 should maybe implement unsion where Legato, Mono and voices can be selected. As unison isnt used as FX
For me this is an absolute must have... Recreating access virus TI leads are practically impossible.
So my request update the editor with an Unison option to turn on or off, as it acts different on the amount of Voices you select
Audio files: 148
PostPosted: Thu May 22, 2008 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget you can load the same patch in multiple slots. Performance mode is very useful sometimes.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
i agree, the first thing wich came up to me was stacking a lot of osc's and modulate them differntly etc. That can result to some more clean sounds but on the other hand , unison combined with these same tunings doubles the power.
Do you think unison would be possible to implement in such complex system? I think a way just like in reaktor added up next to voice mode. And ye Pan Spread wich reacts with the voice combining.
Even if this would be the last update.. this really would make this system Complete! so nowadays users can easily get a full detuned sound without doing to much complex stackings. So you just need 1 osc module instead of 32
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Thu May 22, 2008 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well yes, it is just another voice allocation mode. Like poly but each voice is triggered from a monophonic trigger/note value. They just need to add a control for the amount of detune. Probably why they didn't is the exact same thing can be patched using 2 or 3 existing modules. It's just not as convenient.
unison.pch2
 Filename:  unison.pch2
 Filesize:  1.59 KB
 Downloaded:  1551 Time(s)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Thu May 22, 2008 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
As its just an voice allocation mode in your words. Then why did they not add this in the first place like Korg ms20, Sequential prophet V, Access virus..
atm im reduced to the demo version becouse my g2 is replaced as i properbly mentioned to much allready (variation button 1 is stuck) Razz So if i use this patch on my expanded g2 and allocate more voices does this change the detune and voice allocation?
i will give an example for the specific purposes its about an original Warner Brothers movie theme
+12 semitones Detune on a 6 voice unison allocation. (My Unison Reaktor Movie Lifter.mp3)
is anyone capable reproducing this specific sound and motion without unison?
and just some notes from your unison g2 patch.. (your unsion g2 patch.mp3) (sry for the cheap playing)
if the demo version does not playback your patch as it should let me know. Becouse the more voices you add the more unison should interact, especially at extreme detunes. (octave)
Unison with Reaktor! +12 semitones detune with an envelope point draw system (warner brothers movie lifter)
 Filename:  My Unison Reaktor Movie Lifter.mp3
 Filesize:  151.15 KB
 Downloaded:  815 Time(s)
Your Unison G2 patch.mp3
your unison g2 patch on the demo version mono mode.
 Filename:  Your Unison G2 patch.mp3
 Filesize:  85.02 KB
Audio files: 231
G2 patch files: 319
PostPosted: Thu May 22, 2008 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
No it doesn't as the demo plays one voice only.
The patch is setup to play twelve voices which are detuned from each other by using the "voice no" output from the status module and this is modulated by the note being played through the morph on OscDual's pitch sensitivity.
I don't have a keyboard connected, so I can't really make a recording of this but the example you posted should be doable.
Audio files: 231
G2 patch files: 319
PostPosted: Thu May 22, 2008 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I changed the patch a little bit so it plays itself and I made a recording from that with zero unison to max and back to zero - this was using 12 voices.
g2ian-unison.mp3
 Filename:  g2ian-unison.mp3
 Filesize:  438.49 KB
 Downloaded:  1588 Time(s)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Fri May 30, 2008 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
ill take a carefull look at the voice no output, and do some testing. I only used 6 voices tough.
i see, unfortunatly im still waiting for my modular... it didnt arrive today so will be next week on tuesday..... :S
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Jun 03, 2008 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
About the movie lifter unison style....
i reproduced this
The more slots you use the more sound.
Movie Lifter.prf2
Movie Lifter Performance.
 Filename:  Movie Lifter.prf2
 Filesize:  8.69 KB
 Downloaded:  1331 Time(s)
dorremifasol
G2 patch files: 49
PostPosted: Wed Dec 31, 2008 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Now I remember about the STACK function on the Nord Lead 3. This would be a much better implementation than the unison module. In fact I think it's an absolutely brilliant idea from Clavia.
It could be improved with a "stereo spread" value.
Albert
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Wed Dec 31, 2008 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds interessting, im not sure how that works tough :p
Polyfonic Unison v1 (23 voices)
http://www.electro-music.com/forum/topic-31184.html
Mono Unison (32 voices)
http://www.electro-music.com/forum/topic-28361.html
Here you can download my Unison patches. The mono unison version has no bugs what so ever, but when you use polyfonic unison, each note press changes according to how many keys there can be played at the same time. So if i use 24 max voices, and 12 unison voices the note changes each note press. Its pretty difficult to explain, in this patch i made the bouncing notes unnoticable, you wont notice it too much. If you reduce or heavily detune unison voices the bouncing occurs sooner. If i know how to stabilize this, that would be a big step forward.
There are a lot smart guys here who might be able to figure this out Smile
