choklitlove
Audio files: 17
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Tue Nov 21, 2006 7:27 pm Post subject:
| Wow awesome! and i just got some of those 14 pin beauties in. Thanks a lot, choklit! |
choklitlove
Audio files: 17
Posted: Tue Nov 21, 2006 10:19 pm Post subject:
| goodrevdoc wrote: | | Wow awesome! and i just got some of those 14 pin beauties in. Thanks a lot, choklit! |
if you don't mind my asking, where did you get them from? i had a hell of a time finding some. thanks! |
midgetfidget
Joined: Aug 22, 2006 Posts: 84 Location: melbourne, aus
Posted: Thu Nov 30, 2006 12:32 am Post subject:
| how come you added an extra diode? what sort is it? |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Thu Nov 30, 2006 8:51 am Post subject:
| midgetfidget wrote: | | how come you added an extra diode? what sort is it? |
Looks like the diode is just for protection against hooking up the battery backwards. Any old silicon diode would work. _________________ --Howard
my music and other stuff |
midgetfidget
Posted: Thu Nov 30, 2006 4:46 pm Post subject:
thanks,
another question:
what about the values of q1-4?
I know there are 2 x bc547 and 2 x bc557, which goes where? |
goodrevdoc
Posted: Thu Nov 30, 2006 5:40 pm Post subject:
I got them from halted electronics. They have good prices on a lot of weird stuff. 308 chips for rat distortions are ridiculously cheap, for instance. their stock list also says they have CA3080's for $0.79, but i called and they said they were out of stock..
-justin |
choklitlove
Audio files: 17
Posted: Thu Nov 30, 2006 7:36 pm Post subject:
| midgetfidget wrote: | thanks,
what about the values of q1-4? |
my bad. i was hoping i could update it before anyone caught that. well, i updated it and i think it looks better now too. thanks!
http://www.geocities.com/worthekik//crackle.html
i also deleted the older layout to avoid confusion. |
midgetfidget
Posted: Thu Nov 30, 2006 10:32 pm Post subject:
| cheers! |
midgetfidget
Posted: Sat Dec 02, 2006 11:24 pm Post subject:
I built it today using your design, but i can't get it to work
i have double checked everything. The led won't even turn on.
the chip is getting power at the input pin.
the only thing i can think of is i've used a small 8ohm 5watt speaker, is this too big? maybe the amp can't power it? |
choklitlove
Audio files: 17
Posted: Sun Dec 03, 2006 5:18 pm Post subject:
that's weird that the led won't even turn on. led in the right direction? i would make sure the battery is okay, and all of the obvious stuff around getting the power to R2. you might need a different value for r2 like 4.7k or something.
i'm sure you've looked at everything, but at least the LED should work. |
choklitlove
Audio files: 17
Posted: Sun Dec 03, 2006 6:07 pm Post subject:
| also, you might want to try it without D2, replacing it with a jumper. if something weird is happening with it, it might stop the ground from happening at the battery. just a thought. |
midgetfidget
Posted: Sun Dec 03, 2006 10:20 pm Post subject:
Thanks for the tips.
I've tried everything you've mentioned except checking the led. I mounted it off the board so there's a chance i mucked it up. I'll check tonight when i et home. |
midgetfidget
choklitlove
Audio files: 17
Posted: Wed Dec 06, 2006 6:25 pm Post subject:
awesome! sorry, i can't tell you what it's supposed to sound like. the squealing may be an error in my layout, i don't know. i added the volume pot without testing at all, so maybe this circuit just doesn't work like that (acts strange w/ outputs instead of speaker, maybe the pot's behavior is linked). i'm just not sure.
however, if you think it works well enough to verify the layout, i can go ahead and do that. then, maybe down the road, we can work out the little bugs that you spoke of. also, if you don't mind, i'd like to post a picture of your's on the layout's page. it would have a link to you somehow, if you don't mind. just let me know on both things. thanks, and it looks great! |
Joined: Apr 03, 2004 Posts: 19596 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Wed Dec 06, 2006 6:48 pm Post subject:
| choklitlove wrote: | | [...] maybe this circuit just doesn't work like that (acts strange w/ outputs instead of speaker, maybe the pot's behavior is linked). i'm just not sure. |
A 100 k pot is too high impedant to be loaded with a 4 or 8 ohm speaker, resulting in it to act as an on off switch. The problem is that when using a lower valued pot the impedance for the driving circuit would be too low (and finding a 10 ohm pot won't be really easy). A potmeter is not very suitable for low impedance volume control, the only thing that would really work would be to add an extra amplifier circuit after the pot driving the speaker - but that would isolate the speaker from the ciruit, probably altering its workings.
Having said all that you could try to use a pot of maybe 1 k or 500 ohm using it as a variable resistor in series with the speaker - the volume might not go to zero then and it would not work really well either, but it could be better. Finding a higher impedance speaker, in the old days they used to have 150 ohm speakers, would improve things as well. _________________ Jan |
midgetfidget
Posted: Wed Dec 06, 2006 8:11 pm Post subject:
| choklitlove wrote: | awesome! sorry, i can't tell you what it's supposed to sound like. the squealing may be an error in my layout, i don't know. i added the volume pot without testing at all, so maybe this circuit just doesn't work like that (acts strange w/ outputs instead of speaker, maybe the pot's behavior is linked). i'm just not sure.
You might be right there, as it only squeals when the pot is all the way up. I'll bypass the pot and see what happens. Other than that it sounds similar to samples i've heard.
No problem, feel free to post my pic. I don't have a website, but like everyone else i have www.myspace/patstormont
Thanks for the layout, i might try your atari punk one next. |
choklitlove
Audio files: 17
Posted: Thu Dec 07, 2006 9:18 pm Post subject:
just to let you know, i updated the page and your pic is on it. it really makes the page look better with a completed build on it. when i get around to building it, i'll experiment with pot values and whatnot to make this layout better. i'll let you know if i find anything out. let me know if you do as well, ok? thanks!
http://www.geocities.com/worthekik//crackle.html |
midgetfidget
Posted: Thu Dec 07, 2006 11:13 pm Post subject:
OK here's what i've done so far.
I fooled around with it last night, and i directly wired the speaker to the board, replaced the pot with a 10k linear pot in line with the battery as a voltage starve.
I read somewhere it sounds differnet as the battery dies so i thought i'd try this.
It stopped the constant squealing. It works pretty well for a 1/4 turn or so, but an even weaker pot would work better but I don't have any on hand. It kinda works as a volume control as well. |
crashlander42
Joined: Oct 21, 2006 Posts: 276 Location: Orlando, FL (US)
Posted: Wed Dec 20, 2006 11:39 pm Post subject:
how's this thing supposed to behave? |
| I finished my crackle box, and much to my surprise it makes sound. I was just wondering about the behavior. Pad 7 in combination with any pad makes a lot of pleasing squealing and screeching sounds, and pad one in combination with others makes sounds, but the others don't really seem to do much unless i have a finger on pad 1 or 7. Is this normal, or did I screw something up? Even if it is i still find it pleasing. I don't seem to have any constant sound out of it as was previously reported, but the volume does just turn the sound on or off. |
Audio files: 107
Posted: Thu Dec 21, 2006 7:37 am Post subject:
crashlander42, your experience sounds fairly typical. Things change over time, naturally. That's part of the charm of these things. _________________ --Howard
goodrevdoc
Posted: Sat Dec 30, 2006 10:50 pm Post subject:
Does anyone know if these are actual 709's? The datecode seems appropriate, but i can't seem to make boxes crackle. I've built 4 different versions: breadboard, perf, choklit's layout, and my own layout. None have made even a peep. Also, i'm getting voltage on all 14 pins. Help!
Also Happy New Year everybody!!! |
Audio files: 107
goodrevdoc
Posted: Sun Dec 31, 2006 11:36 am Post subject:
Thanks mosc, that would surely explain my lack of crackle
-justin |
