Switching between two slave-oscillators
Page 1 of 1 [5 Posts]
vorlon
PostPosted: Fri Jan 12, 2007 5:37 pm    Post subject: Switching between two slave-oscillators Reply with quote  Mark this post and the followings unread
Hej!
I searched for almost one hour on this board, but I didn't find a solution to my problem.. (maybe it's too simple to be on this board, so I might be really stupid :p)
I want to switch between 2 slave-oscillators, i.e. if A (Sawtooth) is active, B (Pulse) mustn't be active and if B is active, A mustn't be active..
Any help would be really cool Very Happy
Have a nice weekend!
Wink
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 12, 2007 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something like in the picture below you mean ?
From the context I assume this is an NM Classic topic, so I'm going to move it to that section of the forum. When I'm wrong I'll gladly move it back and I'll say sorry Very Happy
Switch example
 Filesize:  94.71 KB
 Viewed:  1630 Time(s)
vorlon
PostPosted: Sat Jan 13, 2007 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hoi,
Thanks a lot! It works! Very Happy
I never could come to this on my own Smile
Nogmaals hartstikke bedankt van een Hollander in Zweden! (Thanks again from a Dutchman in Sweden!)
Wink
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jan 13, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
geen dank Very Happy
When you remove the switch you can use the x-fader to fade between the wave forms, which might be more versatile and cheaper at the same time.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 13, 2007 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
And when you use the Modulation Input at audio rate (an audio Oscillator), you can make an 'mix' of the two wave forms.
Just for some idea's:
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/
Wout
