why does the KB gate seem to work only 1/16th of the time?
Page 1 of 1 [4 Posts]
Tasha Yar
PostPosted: Tue Jan 16, 2007 3:31 pm    Post subject: why does the KB gate seem to work only 1/16th of the time?
Subject description: I have set up a step sequencer advanced by keypress, but it only advances every 16th time
hello,
I am just beginning to do patches of my own in the Nord Modular G2. I have run across a problem and hope you can help. I apologize if this is too obvious. I would appreciate your feedback.
I want to have a sequencer that is advanced one step every time I press a key. Eventually, I hope to play the G2 by pressing a MIDI pedal switch every time I want the note(s) to advance, while I'm playing a bass guitar. I also will be wanting polyphony, but haven't gotten that far yet. Right now I'm just trying to make it work from the keyboard w/o using MIDI.
The problem I have is that the sequencer doesn't advance until I press the key 16 times. I am using the Gate output of the Keyboard module and connecting it to the Clock input of the Note Sequencer module. (See attached patch.) I wondered if this has something to do with 1/16th notes vs. whole notes, but I'm not sure what adjustment I need. I'm hoping it's a simple problem with a simple solution. Smile
I would really appreciate any guidance you can give me. Thanks in advance!
- Dan (the keyboard player for Tasha Yar)
sheep-test.pch2
 Filename:  sheep-test.pch2
 Filesize:  1.99 KB
 Downloaded:  688 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Tue Jan 16, 2007 3:52 pm    Post subject: Re: why does the KB gate seem to work only 1/16th of the tim
welcome Dan
The voice count for the patch is set to 16. Every time you press a key a new voice is used and in that voice the sequencer progresses one step. After 16 keypresses a full circle is made and the 1st voice will step again. When you'd set the voice count to 1 it would work the way you expect.
Is there a specific reason you want the voice count to be set to 16 ?
Tasha Yar
PostPosted: Tue Jan 16, 2007 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Jan -- thanks a lot!! I didn't notice the voice mode. I used the "Tiny Organ" patch as a starting point, and I didn't realize it used 16 voices. I've changed that and it works a lot better.
Dan
Audio files: 218
G2 patch files: 319
PostPosted: Tue Jan 16, 2007 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good Very Happy
Saves me a walk to the synth to try and have the patch working for 16 voices - I'm sure it could be done though.
