dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
qfingers
Posted: Thu Jan 25, 2007 6:24 pm Post subject:
| dasz wrote: | qfingers,
you and 3phase (and all other q2tools contributors) are A W E S O M E
I just converted my entire Papa Nord library and about 85% of the patches were dead on. Whoa, now I do not miss my Papa Nord at all.
One question, on some patches (most of them), the osc pitch is converted to Hz, could one instead ensure the converted pitch is in semi's?
/Dasz |
Thank you. It's been a wild ride for both me and 3phase. Our only contact has been this forum and this project. He is a monster when it comes to this stuff. We had difficult problems to work out. They are not all there yet. Version 1.3 will probably increase your 85% to higher. There were some minor mishaps on communication between us and we were wearing out.
As far as your question goes, there were places were Hz was used in the patch so I felt it best to keep it at Hz when the patch had it. Other places required different things because of the grey slave connections. So, I would be hesitant to do it because of what things may break. Based on other convertion issues it would be risky. When I start the next major update, I'll look into it though.
I'm hoping for 1.3 out this weekend and taking a month off from the project. I've got another pressing project that's use to pay for my G2X. I've got 4 weeks to finish it and cannot work on both. So after the next release, that's it for a month or two.
q |
dasz
Audio files: 29
G2 patch files: 56
Posted: Thu Jan 25, 2007 8:32 pm Post subject:
Matt and 3Phase,
What I reported is not a bug. The freq button translation is correct - I checked over the patches in the old editor and the oscs were indeed set to Hz.
I forgot the semi button settings is a new name for the note name setting in the Classic.
| Quote: |
You deserve the break. What you have given us is so much more than anyone would expect. A big thanks
/Dasz
ps.: The number of successful conversions of almost 400 patches was 95%! _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/ |
ian-s
Joined: Apr 01, 2004 Posts: 2518 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
Posted: Thu Jan 25, 2007 11:19 pm Post subject:
I got the python function to do the DX2G2 pitchEG rate conversion working, but it is hard to tell how close the result is.
Is anyone able to post or pm me an mp3 of a real DX7 or FM7 etc, playing single notes of the following factory sounds...
Decent
Voices
Flexatone
Funky Rise.
All on Rom cartridge 4 A or B.
They represent enough variation in rates/levels to fine tune the values in my table.
Thanks again to q and Sven for all the work that went into the converter. |
3phase
G2 patch files: 138
Posted: Sat Jan 27, 2007 10:36 pm Post subject:
My initial suggestion for a subforum was actually ment for the lib itself..but ok..we have one now for all converter questions and the lib so
I think it would be good to structure this new subforum a bit better...
My suggestions:
There should be one thread maybe as sticky that is only for handling information to compile the info for the documentation...
so i actually suggest to cannibalize this thread and move the related mails...
one thread that is related to bug finding and discussion..so mainly this thread.. but without a sticky..because it might be not the most actual point of discussion...
A sticky where the application in the actual version is housed, the gui, bugfix list..and when done the documentation..maybe even locked?
A sticky in the main forum to anounce new versions would be nice..
And also as a sticky the Lib itself in whatever form it will be implemented...
Just for the time being this would give a rough structure because there will be own threads for single problems and questions while the main threads got too big already...
Would be good if the link where the actual program can be found is somehow permanent and not too crowded by discussions...
What do you think? |
Tom_1970
Joined: Jan 14, 2007 Posts: 18 Location: The Netherlands
Posted: Sun Jan 28, 2007 3:18 am Post subject:
Version 1.3 works fine so far.
DX conversion also runs smootlhy now.
Thanks a lot for this very handy tool!!!
Regards
Tom |
Tom_1970
Posted: Sun Jan 28, 2007 1:56 pm Post subject:
I have experimented today with the conversion of DX patches.
For my Yamaha DX pluginboard I used DX-manager as an editor/librarian.
The main library file of this editor contains over 5000 DX patches.
By just copying the ones I am interested in and paste them into a new bank, I created a bank with 32 patches. I saved it as a .syx file and converted it with dx2g2.
It works perfect. The patches sound pretty accurate and it's a piece of cake to convert only the sounds you want.
My G2 engine became a true DX7 this way.
You guys did a very good job on this tool.
My thanks and compliments.
Regards
Tom |
3phase
G2 patch files: 138
Posted: Sun Jan 28, 2007 3:28 pm Post subject:
| could you maybe supply the 5000 patches from that editor? maybe they are different to the publik domain ones..or the same but cattegorized.. |
Fozzie
Joined: Jun 04, 2004 Posts: 873 Location: Near Wageningen, the Netherlands
G2 patch files: 49
3phase
G2 patch files: 138
Posted: Sun Jan 28, 2007 5:31 pm Post subject:
can you name the source folder.. = author name?
would be good if any patch that is shown here is alsos supplied with the source adress for later reference... |
Spandex
Posted: Sun Jan 28, 2007 6:29 pm Post subject:
When I run dx2g2 on Linux (Debian) I get errors:-
| Code: |
spandex@pr0k:~/g2ools-1.2$ python -V
Python 2.3.5
spandex@pr0k:~/g2ools-1.2$ python ./dx2g2.py magazine_927.syx
magazine_927.syx 32 voice
/home/spandex/g2ools-1.2/nord/g2/file.py:41: FutureWarning: x<<y losing bits or changing sign will return a long in Python 2.4 and up
return (icrc<<8)^crc
1. **Slaps**
2. Fairlight?
3. Fizz Buzz
4. Downstairs
5. Berlin
6. GlassPiano
7. Soft Grand
8. Timefluss
/home/spandex/g2ools-1.2/nord/g2/file.py:77: FutureWarning: x<<y losing bits or changing sign will return a long in Python 2.4 and up
return (x&~(m<<p))|((m&y)<<p)
Traceback (most recent call last):
File "./dx2g2.py", line 169, in ?
dxconv.pch2.write(outname+'b%d.pch2' % bank)
File "/home/spandex/g2ools-1.2/nord/g2/file.py", line 1071, in write
f = section.format(self.patch)
File "/home/spandex/g2ools-1.2/nord/g2/file.py", line 150, in format
bit = setbits(7*8,5,data,desc.reserved)
File "/home/spandex/g2ools-1.2/nord/g2/file.py", line 92, in setbits
data.extend([ 0 ] * (last-len(data)))
TypeError: can only extend array with array (not "list")
spandex@pr0k:~/g2ools-1.2$ |
I've tried with lots of different syx files, always get the same thing. The one I tried above is one from this thread so I know it's working ok for some people. _________________ --
Lovely Cloakroom.... Lovely Cloaks |
Posted: Sun Jan 28, 2007 6:36 pm Post subject:
| I think most people are using 2.5, or at least 2.4. Looks like you are using 2.3.5. Try to update your python? |
Joined: Apr 03, 2004 Posts: 19596 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Jan 28, 2007 6:40 pm Post subject:
Python 2.3.something gave trouble for me as well on windows, now using 2.5 that works. _________________ Jan |
Spandex
Posted: Mon Jan 29, 2007 2:49 am Post subject:
Ah thanks. I need to run 2.3 for something else. I'll find a way to get both installed. _________________ --
Fozzie
G2 patch files: 49
Posted: Mon Jan 29, 2007 8:00 am Post subject:
| 3phase wrote: | can you name the source folder.. = author name?
It came out of one of the patch collections, so I have no author name. I can look up the path when I'm home tonight.
I did see it a few other times as well, but didn't get alarmed cause I thought it didn't affect sound. In the example I posted it has a clear effect on sound, so I really think those cables operate at 24kHz. Will pay attention and report if I run into them again. _________________ Spinning at ~0.0000115740740741 Hz |
3phase
G2 patch files: 138
Posted: Mon Jan 29, 2007 8:26 am Post subject:
Its ok...that one is fixed allready... mr quickfinger just needed a minute or so...
next one  |
cappy2112
Joined: Dec 24, 2004 Posts: 2089 Location: San Jose, California
Posted: Mon Jan 29, 2007 10:52 pm Post subject:
| Spandex wrote: | | Ah thanks. I need to run 2.3 for something else. I'll find a way to get both installed. |
Are you on XP?
use the environment variables PYTHONPATH and PYTHONHOME
Don't hardcode the path to the interpreter in the path environment variable.
Replace it with %PYTHONHOME% |
3phase
G2 patch files: 138
Posted: Mon Feb 05, 2007 12:32 am Post subject:
So 1.5 is there ....
biggest change is the new -s flag that optimizes the cable conections to increase tzhe overview...
I personally think this should become a default function but i needs to be tested for a while to ensure that it allways does the wright thing. |
torsig1967
Posted: Tue Feb 27, 2007 3:33 pm Post subject:
Tried the g2tools for the first time today and just want to send a big THANK YOU to everyone involved.
Amazing work! |
jjpleeza
Posted: Tue Feb 27, 2007 4:37 pm Post subject:
Some patches aren't converted? |
HI, I just downloaded the new archive of patches for the G2, but a lot of the original NM1 vocoder patches are misssing..
Why is this? Is the converter not complete yet?
Also, a lot of the ones that have been completed didn't sound like the original patches.. Is this due to bugs?
Thanks, Jonny
P.S. Much respekt on all the hard work you guys have done on implementing this software guys! |
ian-s
Audio files: 42
G2 patch files: 584
Posted: Tue Feb 27, 2007 4:48 pm Post subject:
Re: Some patches aren't converted? |
| jjpleeza wrote: | Is the converter not complete yet?
It is early days.
Sounds like you have both NM and G2 so you can help the project if you can diagnose why the two patches don't sound the same and post the results. Or at least post the pch/pch2 pairs so someone else can have a look. |
jjpleeza
Posted: Tue Feb 27, 2007 5:06 pm Post subject:
No, I sold the NM1 when I bought the G2.
Really miss the old vocoder patches though.
I'm far from being s programing guru, so I can't tr-programe these myself.
There are 3 patches I REALLY need.
Classic Vocoder
Saw Vocoder
Phase Vocoder
If anyone can re-create these for the G2 I'll be
happy to swing them some money for their time.. |
3phase
G2 patch files: 138
Posted: Wed Feb 28, 2007 2:37 am Post subject:
| jjpleeza wrote: | ....Also, a lot of the ones that have been completed didn't sound like the original patches.. Is this due to bugs?
This nobody can tell aslong you dont point us to patches that dont sound wright...
There are points where Nm1 and G2 sound different...some patches suffer from this more than others but basicaly it should be close enough that you can see it as the same sound...
but its also possible that there are still bugs that are overseen... when patches drasticaly go wrong it gets interesting |
jjpleeza
Posted: Wed Feb 28, 2007 6:07 am Post subject:
can someone please tell me what the equivalent of the Formant OSC is on the G2?
Jonny |
torsig1967
Posted: Wed Feb 28, 2007 7:09 am Post subject:
| jjpleeza wrote: |
Classic Vocoder
Saw Vocoder
Phase Vocoder
And where can these NM1-patches be found? |
