 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
ABOUT POSTING CODE PLEASE READ.
Page 1 of 1 [4 Posts]
Kassen
PostPosted: Mon Oct 30, 2006 12:30 am    Post subject:  ABOUT POSTING CODE PLEASE READ. Reply with quote  Mark this post and the followings unread
Fellow ChucKists,
When posting code to the board (please do, it's fun!) remember to tick the box to disable html (first option below your text entry field.
If you don't the board will think some of the <triangular brackets> are a part of some html tag. This will first confuse the board, then all of your readers (and listeners, hopefully) as well as the ChucK compiler.
On a related note; the "code" tag should help in keeping code more readable.
Shouldn't the code tag in itself disable html for that part of the post? Erm, yeah. It's not perfect... Yet Wink.
while(!machine.crash() ) <<<"all is well">>>;
Audio files: 83
PostPosted: Mon Nov 06, 2006 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I've added the .ck extension to the forum so ChucK code can be uploaded as attachments. That's probably the safest way to do it.
Kassen
PostPosted: Tue Feb 13, 2007 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Recomendation;
If you don't care about HTML (BBcode can do all that stuff as well as far as fora are concerned) and do care about ChucK it's convenient to go into your profile and disable HTML in your settings.
From there on you won't need to keep remembering to click the "Disable HTML in this post" box.
Audio files: 19
G2 patch files: 281
PostPosted: Tue Feb 13, 2007 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Good tip Kas (as an interested noob I'd prefer to see the code readable and not as an attachment).
Top Selling Products! CLICK HERE!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
